Help Me!
Hossein
Hello all!
My Mini2410 board has 2 push-button to change between NAND and NOR memory.
When I connect the serial and USB cable and turn the power ON it start from
NAND and I can't change it to start from NOR to see BIOS.
thank
TheRegnirps
There is probably a problem with the switch. On the Micro2440 you see the
same thing if you forget to remove a jumper that over-ride the switch.
The switch is a though-hole part, so you can use a meter to see if it is
working.
TheRegnirps
Sorry. Did you say Mini2410? Is it an old FriendlyARM QQ2410?
Hossein
Yes.My board is Mini2410. I think it is different from Micro2440.I solve
the problem.I should first press the NAND button and then press NOR button
too start from NOR.
Thank for your help
