Hello: I own a micro2440 + 7" Innolux LCD board. Kernel 2.6.32.2-FriendlyARM. V4L enabled (both GSPCA and UVC USB webcams). I'm writting a C++ program (OpenCV based) which uses a USB webcam. Here the problem: Many modern webcams perform poorly when plugged to the board: they send raw data (YUV fomart) thus USB 1.1 bandwidth is overloaded. If JPEG pixel format were used instead of YUV, it would perform significantly better. mjpeg-streamer is able to select pixel format. Indeed, I have successfully tested those modern webcam with mjpeg-streamer. But I'm NOT using mjpeg-streamer. OpenCV deals directly with V4L subsystem. Is there any way to tell the V4L driver to set pixel format? Regards
Setting USB webcam parameters (FPS, size, codec)
It's worth to say that there is a way to set pixel format in V4L, but it only works in host PC with Ubuntu: 1st - Install v4l-utils. This could be done through "sudo apt-get v4l-utils" 2nd - run in a terminal (for example): v4l2-ctl --set-fmt-video=width=640,height=480,pixelformat=0 OK, now I have successfully cross-compiled v4l-utils for the mini2440. However, when I invoke v4l2-ctl command, I get the following error: libv4l2.so.0 not found.
My advice: don't waste your time with mini2440 boards. They are worthless rubbish and nobody will help you.
