I sucessfully mount android on a mini6410, with the image provided by friendlyarm. ocasionally the OS freezes and I can do nothing but turn off the device. is there any way to avoid this or prevent that happen? My application is using the device's serial port and ethernet.
Android Freezes
I have the same problem. After a while of the "screen timeout" the systems hangs. did you find a solution?
Can you hook up the debug interface and log all the output before it fails. Ideally use the USB port and the Android SDK to record the ADB output.
