Hi, Board Det : SMDK2416 I am facing problem when loading zImage to the Board. ############################################################## U-Boot 1.3.4 (Jan 5 2011 - 01:38:59) for SMDK2416 CPU: S3C2416@400MHz Fclk = 800MHz, Hclk = 133MHz, Pclk = 66MHz Board: SMDK2416 DDR2 DRAM: 128 MB Flash: 1 MB NAND: 256 MB In: serial Out: serial Err: serial ETH test 1 ETH test 2 Hit any key to stop autoboot: 0 SAM2416EDK # tftp CS8900 Ethernet chip not found?! *** Warning: no boot file name; using 'C0A80A06.img' TFTP from server 192.168.10.100; our IP address is 192.168.10.6 Filename 'C0A80A06.img'. Load address: 0x30000000 Loading: T Abort SAM2416EDK # ###########################################################################
TFTP not working in U-Boot prompt in SMDK2416
Hello, U-boot is not configured to match your network. All the parameters are the parameters set by default in u-boot source code. You have to set the TFTP server ip, the board ip, the image name and so on. setenv ipaddr YOUR_BOARD_IP setenv serverip YOUR_TFTP_SERVER_IP ... saveenv Have a look here http://www.denx.de/wiki/DULG/UBootEnvVariables and here http://www.denx.de/wiki/view/DULG/UBootCmdGroupDownload#Section_5.9.5.6. command is tftpboot [loadAddress] [[hostIPaddr:]bootfilename]
Hi screwface, All the env variables for tftp was set and get saved already. I am getting, the following error,fot tftpboot and tftp commands, "CS8900 Ethernet chip not found?! " and I tried, "tftpboot 0x30008000 192.168.10.93:uImage" I got the error mentioned previously, first, then it is attempting to get file and ended with a time out message. The TFTPServer is tested and file exist. I can not able to ping the IP of the board when it is in Uboot. Any idea to cross check the ethernet on U-boot? Thanks screwface :)
Maybe you should do a deeper think about the "CS8900 Ethernet chip not found" message. Has your board such an ethernet chip?
Manual mentions CS8900 and LAN9115. Which one do you have? http://www.bdtic.com/DataSheet/SAMSUNG/SMDK2416.pdf
Now, i using board tiny2416. Please help me source code u-boot to download board. Help me .... Big thanks
