Bootloader FileSystem Access
Bensingh Beno
Hello Everyone,
I have been using Mini2440/Linux for quite a while. Sometimes when I append
a wrong command or script line into the init.d/rcS file, QTopia does not
boot due to the command failure and I have to do a NAND-FLASH-Restore each
time.
Is it possible to edit the rcS file using Nor Flash Boot or by any other
means to restore/edit the rcS file without requiring a full NAND Restore.
Thanks..
Ben
Reggie
Use uboot and boot from SD card, that way you can mount the nand rootfs
partition and edit it or, ditch using the nand altogether and use SD to
boot from permanently.
