Touch screen problem (at start up only)
david
Hi all,
my touchscreen is working well once logged in (root or user no problem).
If I load an application using touch screen at start up (using rcS script),
then touchscreen doesn't respond.
I checked the "export " needed for the touchscreen and I confirm they are
in the "profile" file, so I can't find any reason.
Any idea ?
Best regards,
David
sam
Qtopia, X11: Touch is linked to the GUI
Console: you'll need to link & use tslib by your own.
david
I am not sure what you mean,
if I launch my Qt app from console (after logged in) touchscreen works.
If I launch my Qt app from console by a "rcS" script touchscreen doesn't
work. (I have created a "S70myapp" script which launches /home/ftp/scr
which is my app).
regards,
David
david
I finally found !
I had to repeat the export needed for touch screen is the S70myapp just
before the line executing my app.
It's seems not enough to have the export in the "profile" file
ayyap
In my nec3.5" lcd touch screen the display was aligned to right with some
portion not displayed.
According to a post I tried the command ts_test in the terminal of the
board.command not found is displayed in the terminal.
How I have to make the alignment normal.
robert
Here is the answer
http://www.friendlyarm.net/forum/topic/1246
Spare your zImage_N35 on zImage_T35.
Success.
Sudhanshu Mehta
Hi All,
Copy data from "profile" file and paste it in "rcS" file under /etc/init.d
file at its end. then execute application inside same rcS file.
it will work
thanks
sudhanshu
