I'm trying to use the tiny210 module in a custom device with an 800x600 screen, different from the ones that come with the dev board. Everything is wonderful under Linux. Not so under Android. It appears that the binary-only file /linuxrc is supposed to do the touchscreen calibration. In fact it seems to be mostly a recompiled ts_calibrate, but there is no source available (contrary to the GNU license I may add). If I don't include the skipcal=yes on the command line the system crashes not being able to open the touchscreen device. No surprise here - I don't have "1wire", I have normal s3c resistive touchscreen. I have no problem doing the calibration under Linux. I can also recompile ts_calibrate as a static binary to run with the Android kernel, but Android doesn't use the /etc/pointercal file. There is another binary-only file "/sbin/tsd" that appears to deal with the touchscreen, but again no source. So my questions are: 1. Is there a way to tell the system to use /dev/input/event1 and calibrate the touchscreen? 2. Where is the source for /linuxrc and /sbin/tsd? 3. Anybody running Android with a resistive ts? -Alex.
Android resistive touchscreen calibration
/linuxrc has nothing to do with the touchscreen. You need tslib installed and the correct env vars set at the very least to run ts_calibrate, ts_calibrate should in theory produce the pointercal file that it needs once you've calibrated. google tslib.
