I'm trying to improve an embedded system here at work, namely in restructuring the partition layout. I am definitely new to embedded work, but not new to Linux in the least. My hardware is an i.MX27 CPU on a board with 32mb NOR flash and 512mb NAND, among other things. I'm running barebox 2010.04.0 and Linux 2.6.33.3 from ptxdist 2010.04.1. It's all out of date, but I figured I should stick with what the board manufacturer provided us until I could muster true command of the system. Originally, the partition layout was: ---------------------------------------------------------------------- nor_parts="256k(barebox)ro,128k(bareboxenv),2560k(kernel),-(root)" #rootpart_nor="/dev/mtdblock3 ro" nand_parts="256k(barebox)ro,128k(bareboxenv),3M(kernel),32M(root),32M(usr_l ocal),32M(ifp),-(data)" rootpart_nand="/dev/mtdblock8 ro" ---------------------------------------------------------------------- They had tried booting from NOR in the past but gave up and stuck with housing barebox on NOR and the rest on NAND. The issue is, where we store our software (ifp), between unreasonably verbose log output and needless backups (I'm working on those issues in parallel with this), 32 megs gets eaten up extremely quickly. So, I modified the layout to the following: ---------------------------------------------------------------------- nor_parts="256k(barebox)ro,128k(bareboxenv)" nand_parts="3M(kernel),-(root)" rootpart_nand="/dev/mtdblock4 ro" ---------------------------------------------------------------------- Now, when I boot, I get the following output: ---------------------------------------------------------------------- barebox 2010.04.0 (Oct 19 2011 - 17:46:52) Board: Phytec phyCORE-i.MX27 cfi_probe: cfi_flash base: 0xc0000000 size: 0x02000000 NAND device: Manufacturer ID: 0x2c, Chip ID: 0xac (Micron NAND 512MiB 1,8V 8-bit) Bad block table found at page 262080, version 0x01 Bad block table found at page 262016, version 0x01 imxfb@imxfb0: i.MX Framebuffer driver cfi_protect: protect 0xc0040000 (size 131072) Using environment in NOR Flash Malloc space: 0xa7500000 -> 0xa7f00000 (size 10 MB) Stack space : 0xa74f0000 -> 0xa7500000 (size 64 kB) running /env/bin/init... Verifying Checksum ... OK Image Name: Linux-2.6.33.3 Created: 2011-11-02 22:06:56 UTC Data Size: 2114112 Bytes = 2 MB Load Address: a0008000 Entry Point: a0008000 OK commandline: console=ttymxc0,115200 mt9v022.sensor_type=color pcm038_otg_mode=device root=/dev/mtdblock4 ro rootfstype=jffs2 mtdparts="physmap-flash.0:256k(barebox)ro,128k(bareboxenv);mxc_nand:3M(kern el),-(root)" arch_number: 1551 Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 2.6.33.3 (root@teckla) (gcc version 4.3.2 (OSELAS.Toolchain-1.99.3) ) #253 PREEMPT Wed Nov 2 17:06:53 CDT 2011 CPU: ARM926EJ-S [41069264] revision 4 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: ULCB-i.MX27 Memory policy: ECC disabled, Data cache writeback Built 1 zonelists in Zone order, mobility grouping on. Total pages: 15808 Kernel command line: console=ttymxc0,115200 mt9v022.sensor_type=color pcm038_otg_mode=device -init=/sbin/init root=/dev/mtdblock4 ro rootfstype=jffs2 mtdparts="physmap-flash.0:256k(barebox)ro,128k(bareboxenv);mxc_nand:3M(kern el),-(root)" PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 32MB 32MB = 64MB total Memory: 60576KB available (3916K code, 267K data, 112K init, 0K highmem) Experimental preemptable hierarchical RCU implementation. NR_IRQS:272 MXC GPIO hardware MXC IRQ initialized Console: colour dummy device 80x30 Calibrating delay loop... 199.06 BogoMIPS (lpj=995328) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok regulator: core version 0.5 NET: Registered protocol family 16 bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Advanced Linux Sound Architecture Driver Version 1.0.21. regulator: REG1_BKLT: 4500 <--> 5500 mV at 5000 mV regulator: REG2_CPU: 2640 <--> 3877 mV at 3300 mV regulator: REG3_CORE: 1160 <--> 1703 mV at 1450 mV regulator: REG4_DDR: 1440 <--> 2115 mV at 1800 mV regulator: REG5_PERS: 2640 <--> 3877 mV at 3300 mV mc34704 1-0054: Loaded Switching to clocksource mxc_timer1 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. i.MX27 CPU frequency change support initialized 133000 399000 JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. msgmni has been set to 118 alg: No test for stdrng (krng) io scheduler noop registered (default) imx-fb imx-fb.0: i.MX Framebuffer driver Serial: IMX driver imx-uart.0: ttymxc0 at MMIO 0x1000a000 (irq = 20) is a IMX console [ttymxc0] enabled imx-uart.1: ttymxc1 at MMIO 0x1000b000 (irq = 19) is a IMX imx-uart.2: ttymxc2 at MMIO 0x1000c000 (irq = 18) is a IMX imx-uart.4: ttymxc4 at MMIO 0x1001b000 (irq = 49) is a IMX imx-uart.5: ttymxc5 at MMIO 0x1001c000 (irq = 48) is a IMX brd: module loaded loop: module loaded at24 1-0052: 4096 byte at24 EEPROM (writable) physmap platform flash device: 02000000 at c0000000 physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank Intel/Sharp Extended Query Table at 0x010A Intel/Sharp Extended Query Table at 0x010A Intel/Sharp Extended Query Table at 0x010A Intel/Sharp Extended Query Table at 0x010A Intel/Sharp Extended Query Table at 0x010A Using buffer write method Using auto-unlock on power-up/resume cfi_cmdset_0001: Erase suspend on write enabled in p cmdlinepart name cmdlinepart p cmdlinepart name cmdlinepart 2 cmdlinepart partitions found on MTD device physmap-flash.0 Creating 2 MTD partitions on "physmap-flash.0": 0x000000000000-0x000000040000 : "barebox" 0x000000040000-0x000000060000 : "bareboxenv" Generic platform RAM MTD, (c) 2004 Simtec Electronics mtd-ram mtd-ram.0: registered mtd device NAND device: Manufacturer ID: 0x2c, Chip ID: 0xac (Micron NAND 512MiB 1,8V 8-bit) p X—AÀ˜™‘Ñ name RedBoot RedBoot partition parsing not available in p cmdlinepart name cmdlinepart p cmdlinepart name cmdlinepart 2 cmdlinepart partitions found on MTD device mxc_nand Creating 2 MTD partitions on "mxc_nand": 0x000000000000-0x000000300000 : "kernel" 0x000000300000-0x000020000000 : "root" spi_imx spi_imx.2: probed FEC Ethernet Driver fec: PHY @ 0x0, ID 0x00221513 -- unknown PHY! ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver mxc-ehci mxc-ehci.1: initializing i.MX USB Controller mxc-ehci mxc-ehci.1: Freescale On-Chip EHCI Host Controller mxc-ehci mxc-ehci.1: new USB bus registered, assigned bus number 1 mxc-ehci mxc-ehci.1: irq 54, io mem 0x10024200 mxc-ehci mxc-ehci.1: USB 2.0 started, EHCI 1.00 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: Freescale On-Chip EHCI Host Controller usb usb1: Manufacturer: Linux 2.6.33.3 ehci_hcd usb usb1: SerialNumber: mxc-ehci.1 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. Freescale High-Speed USB SOC Device Controller driver (Apr 20, 2007) mice: PS/2 mouse device common for all mice rtc-ds1307 1-0068: rtc core: registered ds1339 as rtc0 i2c /dev entries driver i.MX SDHC driver usbcore: registered new interface driver usbhid usbhid: USB HID core driver PMIC Character device: successfully loaded ALSA device list: No soundcards found. oprofile: using timer interrupt. TCP cubic registered NET: Registered protocol family 17 regulator_init_complete: incomplete constraints, leaving REG5_PERS on regulator_init_complete: incomplete constraints, leaving REG1_BKLT on rtc-ds1307 1-0068: setting system clock to 2012-10-24 19:13:06 UTC (1351105986) WM9711/WM9712 SoC Audio Codec 0.4 asoc: AC97 HiFi <-> imx-ssi.0 mapping ok VFS: Mounted root (jffs2 filesystem) readonly on device 31:4. Freeing init memory: 112K Warning: unable to open an initial console. Kernel panic - not syncing: No init found. Try passing init= option to kernel. Backtrace: [<c002817c>] (dump_backtrace+0x0/0x108) from [<c03258e0>] (dump_stack+0x18/0x1c) r6:c001fc80 r5:c0424a94 r4:c03fb984 [<c03258c8>] (dump_stack+0x0/0x1c) from [<c0325934>] (panic+0x50/0x150) [<c03258e4>] (panic+0x0/0x150) from [<c0024640>] (init_post+0x100/0x198) r3:00000008 r2:00000005 r1:d18002a0 r0:c03a0898 [<c0024540>] (init_post+0x0/0x198) from [<c00084d4>] (kernel_init+0x104/0x13c) r5:c001ffd0 r4:c001ffd0 [<c00083d0>] (kernel_init+0x0/0x13c) from [<c003c50c>] (do_exit+0x0/0x724) r6:00000000 r5:00000000 r4:00000000 ---------------------------------------------------------------------- If I change the rootpart_nand parameter to something like mtdblock1 (following t...stripped-down
Kernel panic when rearranging NAND partitions
...and apparently I exceeded the max character count per post or something? Anyway, what should end the post is: If I change the rootpart_nand parameter to something like mtdblock1 (following the logic that (kernel) would be 0 and (root) would be 1), I receive the following boot output (trimmed where they're the same for your reading convenience): ---------------------------------------------------------------------- barebox 2010.04.0 (Oct 19 2011 - 17:46:52) [...] commandline: console=ttymxc0,115200 mt9v022.sensor_type=color pcm038_otg_mode=device root=/dev/mtdblock1 ro rootfstype=jffs2 mtdparts="physmap-flash.0:256k(barebox)ro,128k(bareboxenv);mxc_nand:3M(kern el),-(root)" arch_number: 1551 Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 2.6.33.3 (root@teckla) (gcc version 4.3.2 (OSELAS.Toolchain-1.99.3) ) #253 PREEMPT Wed Nov 2 17:06:53 CDT 2011 CPU: ARM926EJ-S [41069264] revision 4 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: ULCB-i.MX27 [...] WM9711/WM9712 SoC Audio Codec 0.4 asoc: AC97 HiFi <-> imx-ssi.0 mapping ok jffs2: Too few erase blocks (1) List of all partitions: 1f00 256 mtdblock0 (driver?) 1f01 128 mtdblock1 (driver?) 1f02 2048 mtdblock2 (driver?) 1f03 3072 mtdblock3 (driver?) 1f04 521216 mtdblock4 (driver?) No filesystem could mount root, tried: jffs2 Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,1) [...] ---------------------------------------------------------------------- The same holds for mtdblock82 or something random. When I try passing init=5 or init=/sbin/init to the kernel, it doesn't change anything. Give that I know /dev/nand0.root is actually 521216k in size, I'm confused as to why root=/dev/mtdblock4 doesn't work. Any help? Thanks in advance. =)
Seems you are using a modified Barebox. Did you free its C code from any parition assumptions on the NAND device? How did you fill the root partition with its content? Did you try to boot via NFSroot and have a look how the system sees the three kind of MTD devices (NOR, RAM and NAND)?
What area of barebox should I examine to see whether it's presuming a partition layout? I used the _update script that exists in my barebox install, which utilizes tftp to write to flash. I am unsure how to do an NFSroot boot with my setup (ethernet for tftp and serial for terminal I/O). Any pointers?
Due to an chicken-egg problem the platform code must register at least the persistent environment. And sinse the environment partition is behind the barebox partition, the platform code must register two fixed partitions in the boot media. And these (offset and size) must correspond with the settings in the mdtparts variable. It seems you changed the boot media from NAND to NOR. In this case you should remove all partition registering from inside the C code from the platform code (arch/arm/board s/friendlyarm-mini2440/mini2440.c, function mini2440_devices_init() )
Ok, so I found the function (in board/pcm038/pcm038.c) and see the initialization code, but don't see anything troublesome there. Near the bottom of the function, it creates self0 and env0 and then sets the boot params to 0xa0000100 casted to a void pointer. I'm not sure what's there, but I also don't know how to find out. Then it sets the architecture and returns. The thing is though, this device has always booted from NOR, and succeeds with the original partition layout. In the event that I didn't understand your reason for pointing me to that devices_init(), though, I am still listening. =)
It was just an idea what could be wrong with your system. I would recommend now to boot this machine via NFSroot and then you can take a look into the running machine, how the MTD devices are really counted, and what the correct on is from kernel's point of view to act as its root filesystem.
