Hi, Did someone manage to get capacitive touchscreen working under Linux with mini210s, I mean S700? The touchscreen driver is Goodix gt801. I tried to understand why it works with Androïd and not Linux as the kernel is quite the same (3.0.8). The thing I do not understand is located in the drivers\input\touchscreen\Makefile file. At the end of this file, we can see this lines bloc : ifneq ($(wildcard drivers/input/touchscreen/goodix_touch.c),) ifeq ($(FA),1) obj-$(CONFIG_TOUCHSCREEN_GOODIX) += goodix_touch.o else obj-m += goodix_touch.o endif #FA endif But I found no goodix_touch.c file in any directory. All that I found is the *.h file. ¤ So I wonder how is the touchscreen working under Android as there no driver source for the touchscreen (I found the file googling a bit, for Android tablets mainly) ¤ What is different between Android and Linux which could explain touchscreen is working for Android and not Linux? Thanks for your explanations if any!
[Mini210s] S700 capacitive screen under Linux
I tried to use Android kernel which runs fine (touchscreen OK) in Debian linux distro. No touchscreen then. Furthermore, there is also no sound and no WiFi. I don't know why as zImage is the same! If you have any suggestion, feel free
It seems the capacitive screen works only with Android. I wasn't also able to find goodix_touch.c compatible with Linux kernel.
did you look for the goodix_touch.so file in the android images? or google for good_touch.c? first link will find you the file. https://bitbucket.org/paulobrien/android_kernel_andypad/src/4c6b4f4c48d1... This looks like a reasonable resource too: http://translate.google.co.uk/translate?hl=en&sl=zh-CN&u=http://... for some reason I can't get to the www.goodix.com website directly.
I tried good_touch.c without success (incompatible with 2.6.35 kernel). Quick investigation over kernel sources gave me: 1. You can find usage of "ctp" boot parameter in: arch/arm/mach-s5pv210/mini210-lcds.c 2. i2c touchscreen types are enumerated in: arch/arm/plat-samsung/include/plat/ctouch.h however - "CTP_GT80X" value isn't used in any .c file. 3. i2c registers gt80x device, you can see it in dmesg: i2c i2c-2: client [gt80x-ts] registered with bus id 2-0055. 4. "gt80x-ts" name is defined in: arm/mach-s5pv210/mach-mini210.c My conclusion is - either the driver is hidden in closed-source kernel binaries and it's broken or it's just missing sources for the most important part - communication via i2c. I found also "goodix-gt80x.c" file in archos repository, it compiles and loads properly, but it also doesn't work: i2c-core: driver [goodix-gt801] registered
how do you mean it doesn't work? In general you have tslib and run something like ts_calibrate the very first time you boot the machine.
I guess there is no special device /dev/touchscreen-1wire as when using resistance touchscreen, so I expect touchscreen available in /proc/bus/input/devices. And I suppose hexdump /dev/input/event0-9 retuns some data when pressing the screen. Am I wrong? Android doesn't use extra calibration - the screen is already calibrated to 800x480 resolution.
Unfortunately I'm running the 210S with a 4.3" resistive screen so I can only give suggestions based on what I'd look at to fix it up but with no way of testing at all I can't check any further. my only other thought would be to pull the goodix_touch.o from the android ICS image if it's available. I also found out that the s5p-tv driver (deals with hdmi) doesn't exist in kernel 3.0.8 but does exist in kernel 3.1.x so I wonder if a kernel bump would help, although as I understand things we would then be without an mlc nand driver (it's pre-built for the 3.0.8 kernel sources).
I remember I made a "cat /dev/input/eventx" (with x=4 if I remember correctly) with supplied ICS image, and I got some data pressing the screen. But I was not able to get this file using 3.0.8 kernel or Linux 2.6.35 kernel. All that I found is drivers are not compiled as built natively in the kernel but they are modules. That's also why no soundcard is detected by the kernel. Sound module is called by /etc/init.d/rcS script. I guess it is the same for the touchscreen module with Android. I think finding how Andoid calls the driver and doing the same with linux could be a try. Anyway, I think it would be nice to have an up to date kernel with everything supported directly, like mini2440 one (I don't know mini6410). But I'm not good enough, I'm too noob to do that. I asked Juergen, but nothing is planned on Pengutronix side :-( It would have been a great help! I'm also looking for a barebox / uboot port for the mini210 but seems there is nothing for the moment. Just a chinese version I didn't try for the moment.
I try to use FT5306 I2C capacitive TSP with MINI6410. Did somebody managed to run any capacitive TSP to this machine ?
