mini2440 boot problem
recep
I have a mini2440 I tried to install linux but I failed now when I connect
to board via DNW tool there is no boot menu what will I do thanks for helps
With the NOR/NAND switch in the NOR position and a verified working DNW if
you don't get the boot menus THEN it is probably time to "JTAG the
bootloader".
Do you get any indication that DNW is working?  IE comms established or ?
It has been more than one year since I used it.  There will lots of
previous threads on how to restore your bootloader, IF you have lost it.
recep
so how can I install boot menu I just want to install qtopia
Before you rush off and try to put a bootloader into NOR you really want to
make sure DNW is working properly.
Have you setup DNW correctly and can you open the correct comm port?
If you are positive that DNW is working correctly then search for
"JTAGingTheNOR.pdf".  You will need the JTAG "wiggler" hardware device that
comes with the kit of parts.
saiprakash
hi
i have boot problem when i connected to pc ...usb is ok but it doesn't
shown the which com port it is
androjes
Hi all,
After each restart, the mini35 doesn't boot any more.
So, I need to flash it after each restart (using reset bouton) or power-off
(using switch).
Someone can explain me what is the wrong?
ferite
Maybe you are using an old OS image on a newer board (Superboot).
androjes
Now the problem doesn't occur. It is really random grrrr
Yes I use old kernel image.
