Is it possible to set an GPIO Input over the /sys filesystem? After creating f.e. GPIO 165 by echoing 165 to /sys/class/export the direction is declared as "in", the edge as "none". The value is always "0" even if there is an input of 3.2V - 3.3V. If i set the edge to "rising", "falling" or "both" the value always is "1", not respecting the input signal. Is this caused by using the filesystem instead the library or what i am doing wrong? Thanks in advance, Titus
Pengutronix - GPIO Input
I only verified that the GPIO Usage example (8.4.1) worked. If you don't set edge does the input work as expected?
Hi Dave, no, if edge has the default value of "none" the value is always "0". How much amperes are expected by the GPIO as input? On the side of my circuit it is limited this time to about 30 mikroA. (3.2V and 100 kOhm).
Titus, If you are connecting a 100K resistor to gpio165 and then to 3.2V the input will be pulled high permanently. Following 8.4.1 when you export gpio165 do you find a directory /sys/class/gpio/gpio165 and in that directory active_low direction edge subsystem uevent value That example is for setting a GPIO up as an output, so you will need to modify. Have you been able to follow the complete example 8.4.1 and turn the port on and off (as an output)?
Yes, as an output the ports are working as expected for on and off and switching an external opto-coupler. This is the thing confusing me. So i thought there is maybe a minimum amount of current needed for triggering the input. I'll try to search for a failure in my connection from circuit to board now... I want to pullup the port when there is a input of 3.2V and pulldown the port if the input is nearly 0V. Is the value "none" for edge the right choice or have i set it to "both" or another value?
I found another problem... Input signal of constantly 3.2V DC is connected over a 100 kOhm resistor to GPIO input. Before the resistor the power stays 3.2V. Between resistor and GPIO the power amounts a few hundred mV. Why that??? What is the input impedance of the GPIO inputs? Thanks, Titus
> Why that??? What is the input impedance of the GPIO inputs? If you are using a digital multimeter (say 10MegaOhms input or higher) it should not affect the reading at the junction of the resistor and the GPIO. I'd guess the port is configured as an output low, so the voltage gets dropped to almost zero. A test . . . place a LED and a 1K resistor from to 3.2V to the GPIO and see if it lights. LED has to be the correct polarity. Input impedance of the GPIO is quite high. Guess up to MegaOhms. Also, setting the edge parameter I believe is only needed if you want to use that GPIO as an interrupt source. edge = none for interrupt on level change. edge = raising, falling or both for interrupt on the respective changes. > I want to pullup the port when there is a input of 3.2V and pulldown the > port if the input is nearly 0V. Is the value "none" for edge the right > choice or have i set it to "both" or another value? Re-word this to . . . I want my software to indicate a HIGH when I put 3.2V on the GPIO and a LOW when I put 0V on the GPIO. All I do in my application using a GPIO as an input port is to just export it: echo 193 > /sys/class/gpio/export This (by default) sets the port to input and internal pull-up resistor disabled. If you put a multimeter on this port you will see the voltage changing or floating, ie it can read anything between 0V and 3.2V. If you want to define the input level either you enable the internal pullup resistor OR place an external resistor (ie 100K) either to 3.2V (for external pull-up) or to 0V (for external pull-down).
I am not sure about edge = none. According to the datasheet it looks like an interrupt can be generated on going to a low level or going to a high level. Also, I do not know what they mean by "active_low" or the keywords to set it with respect to a GPIO. From the datasheet EXTERNAL INTERRUPT CONTROL REGISTER The 24 external interrupts are requested by various signaling methods. The EXTINT register configures the signaling method among the low level trigger, high level trigger, falling edge trigger, rising edge trigger, and both edge trigger for the external interrupt request Ah, in the kernel documentation and gpio.txt near the last page both "none" and "active_low" are explained.
Hi Dave, thank you for your answer and sorry for my bad and misunderstandable English. Usage as output works perfectly. But when i configure as input by echo 165 > /sys/class/gpio/export and connect a voltage of 3.2V it was dropped down in the following way: ------- ---------x-----] [-----x----------( GPIO Input ------- 3.2V 100 kOhm 0.3V It acts like an voltage divider between the resistor and the input. So it is normal that the input is low with 0.3V. But i do not understand why the voltage drops down.
Aaaaah... the to lines of the resistor were not correctly formatted :-( 3.2V ------x---- 100kOhm -----x-- 0.3V -----( GPIO INPUT
If the GPIO is really configured as an input with the internal pull-up resistor either enabled or disabled AND you connect a 100K resistor from 3.2V to that input . . . the GPIO pin should be at 3.2V. Remove the 100K resistor and tell me what you read.
Note: GPAxx are only outputs GPFx and GPGxx can be configured to use interrupts. "edge" should have no effect on the other (non-interrupt capable) ports. I can work it out, but you tell me which GPxxxx is 165.
165 is assigned to GPF5. I want to use GPF3, GPF5 and GPF6 as inputs. If there is no need to configure edge for reading voltage on and off from the ports it would be fine. I am not at home this moment, so i test the inputs without the 100kOhm resistor if there would be no harm to destroy the chip with too much current. GPG1 / 193 is not wired to the connector on my micro2440. The micro2440 has only a 20 pin connector for GPIO and ADC and a 20 pin connector for the camera. GPG1 isn't available on the camera port too. What do you mean with "internal pull-up resistor either enabled or disabled" ? How can i enable the internal pull-up resistor? Are there more steps necessary than echoing the ports number to /sys/class/export? Thank you for your help!
OK, GPF5. It can be either an input or an output AND can be used as an interrupt port. > If there is no need to configure edge for reading voltage on and off from > the ports it would be fine. I would expect the default would to be have the port as a non-interrupt port, so don't worry about configuring the "edge" value. > . . . so i test the inputs without the 100kOhm > resistor if there would be no harm to destroy the chip with too much > current. How would any current flow without the 100KOhm resistor? Even if you connect an INPUT port up to 3.2V only microamperes will flow. However, if the port is configured as an OUTPUT LOW and you connect it to 3.2V then you might damage it. Likewise, configuring a port as OUTPUT HIGH and then connecting it to ground you might damage it. Maybe, the chip has good internal current limiting for these conditions but I would not rely on it. Read about the "sink" and "sourcing" capabilities on I/O port and whether or not they are protected from damage. Also, read about "bus contention" > What do you mean with "internal pull-up resistor either enabled or > disabled" ? How can i enable the internal pull-up resistor? Are there > more steps necessary than echoing the ports number to /sys/class/export? According to 8.4.1 you can set the "direction" (input or output), "value" (high or low for an output port). According to the kernel doc referred to above you can set the "edge" (none, rising, falling or both). I think "edge" by default must be set to a condition which makes the port act like an non-interrupt port. As soon as you set "edge" to one of the 4 parameters then it must start behaving as an interrupt port. > How can i enable the internal pull-up resistor? I have looked through the docs and can't find the answer. I suspect that when the GPIO is configured as input then "value" will turn the internal pull-up on and off. Yikes, just read "Note that requesting a GPIO does NOT cause it to be configured in any way" Probably, best to explicitly set the "direction" to "in" and the pull-up to the "value" you want (if that is the correct term to use). "The harder you look the more there is to it".
Doing: echo 193 > /sys/class/gpio/export echo low > /sys/class/gpio/gpio193/direction sets the port to output low, see kernel docs (gpio.txt) Then the docs say, "and using 'value' If the GPIO is configured as an output, this value may be written . . ." (echo out > /sys/class/gpio/gpio193/direction) echo 1 /sys/class/gpio/gpio193/value makes this output port high. Likewise, (echo out > /sys/class/gpio/gpio193/direction) echo 0 /sys/class/gpio/gpio193/value makes this output port low. Now, for input ports echo in > /sys/class/gpio193/direction should set it to an input port. When it is set up as an input port you can (only) read the "value". By default it appears that the pull-up is enabled as I read 3.3V steady on the pin and a 10K resistor drops the voltage to about 1.7Volts. Therefore, I conclude that the internal pull-up resistor is close to 10K. Looking in mach-mini2440.c I see some lines like: /* remove pullup on optional PWM backlight - - */ s3c_gpio_setpull(S3C2410_GPB(1), S3C_GPIO_PULL_UP); I don't see information which suggests you can disable the pull-up from userspace (sysfs). I am sure a some stage I saw my inputs floating to indeterminate values, indicating no pull-ups enabled, but not today! Several reasons I do all my IO and peripherals using a ATmega32U4 board and talk to it via USB!!
Hi Dave, thank you for your detailed explanations. Today i soldered a 560Ohm resistor parallel to the 100KOhm. At the input were only about 1000mV. With a 10KOhm it is about 700mV. This will be the same if i switch off the board and measure connected to the powerless board. Strange behavior! So i tested it with another, newer micro2440 Board and got 1.5V over the 100kOhm resistor at the powerless board. Oh my goodness, i fear the other board has broken GPIO inputs. As an output they are working as expected but as input they have too low resistance and drop down the voltage :-((( All other IO are working including ADC and linux system is running stable. Very strange, but i have no other answer on it as changing the board. So sorry for causing the confusion here and your wonderful help! Titus
> By default it appears that the pull-up is enabled as I read 3.3V steady > on the pin and a 10K resistor drops the voltage to about 1.7Volts. > Therefore, I conclude that the internal pull-up resistor is close to 10K. I should clarify this statement: I am connecting the 10K resistor from the input pin to GROUND and measuring the voltage at the junction. BTW, this seems a low value for an internal pull-up, I expected more like 100K. Tonight I'll verify what happens when a I connect various series resistors from 3.3V to the input pin. I would not be doing any tests without power on the board and trying to draw a conclusion about whether or not the port "would work". Does the newer micro2440 board's GPIO work properly?
Hi Dave, i just tested with the powerless board because the probably broken one pulls down the power too in powerless state. If the other one works properly i will test when back at home. This times i stay at Ibiza to test the generally function of my project, prepare the location and do some other organizations with my friend here for it. At end of the week i will be back in Germany and then i test the effects with the other board. I am frightened the i maybe damaged the inputs with my circuit by putting power to them before they are configured (by /sys/class/gpio/export). I have not enough equipment here to do saver tests. Thank you for your help! I'll report when i am back at home.
Configuring an GPIO should not make any difference to its ability to withstand damage. It will be just as fragile configured or not! Still couldn't find out what values the pull-up resistors are. I see I said I would do some testing, which will have to wait a few days as I am away from home.
In the S3C2440 datasheet there is a table which lists details for each pin one of which is "I/O Type". GPFX pins have I/O type "t8" which is described in another table as: "Bi-directional pad, LVCMOS schmitt-trigger, 100k pull-up resistor with control, tri-state, Io = 8mA" Also, the GPF5 on the mini2440 already has a 10K pull-up connected to it. If you are pulling down a 10K resistor I can think of 3 possibilities. 1) The pin is configured as an output. 2) There is something else connected to this pin pulling it down. 3) The I/O circuitry for the pin is damaged. Regards, Rob
Rob, I now see that a lot of the GPIO have external 10K resistors pulling them up to 3V3!! That explains my test results. > If you are pulling down a 10K resistor I can think of 3 possibilities. May, I add a few words: If you are pulling a port with an external 10K resistor to 3V3 down close to ground . . . Thanks for the clarification. Titus, have you got this sorted yet?
