Hi, I just bought a 210s board, and I wanted to change the OS in the NAND. When I switch the board to NOR and power on it, nothing happen on the serial port, the card just beep. What sould I do ?
Mini210s no bootloader in NOR
I think, there is no NOR memory in Mini210s. This switch is to boot from SD card. You have to install superboot on SD card using sd-flasher tool and also copy kernel and root filesystem.
Tomasz you are correct, there isn't a nor chip on the mini210S. There are some tutorials for the mini210S here: http://armworks.cc/index.php?title=Mini210S#Tutorials_And_how_tos
