Hey guys, Im new to I2C/SMBus stuff in linux. I am trying to interface an IR sensor to the system (MLX90614). I read in the datasheet that the device is SMBus compatible, but only with the READ WORD and WRITE WORD functions. I have the following code: //Open i2c bus file = open("/dev/i2c/0", 0); if(file < 0) { exit(1); } /* Set Slave Address */ if(ioctl(file, I2C_SLAVE, 0x5A) < 0) { if(errno == EBUSY) { printf("UU "); } else { fprintf(stderr, "Error: could not set address to 0x%02x: %s\n", 0x01, strerror(errno)); return -1; } } if( ioctl( file, I2C_PEC, 1) < 0) { fprintf( stderr, "Failed to enable PEC\n"); return -1; } __uint8_t reg = 0x07; /* Device register to access */ int dataH = i2c_smbus_read_word_data(file, reg); usleep(100); printf("DataH: %X\n", dataH); Now, this code works! ...once. Upon a fresh boot, i can run a program with this code and get the correct data from register 0x07. If I try to run it again, it may or may not work. I get SMBus timeouts waiting for bus to be idle followed by failures to get the bus. What am I not doing correctly here?? Am I missing some steps? Thanks for the help! -Ryan
SMBus usage with Tiny6410-SDK
I should also mention that I do not get these problems when I use READ BYTE or WRITE BYTE functions, however, since they are not supported, the data bytes I receive are 0xFF.
