I have a SKY2440 development board with 256M NAND (K9F2G08). I am using u-boot 1.1.6 that was pre-installed in NOR and DNW 0.49. When I attempt to simply download to RAM and run (option 7) to address 0x30000000 it will work fine with images less than 512K. When I download a larger image 1,566,716 bytes in size, u-boot reports "RECEIVED FILE SIZE: 1566726 (765KB/S, 2S)". When it attempts to run it will sometimes display the error message "invalid instruction" or "data abort" with a register dump, or no error message at all, and then resets the CPU. This image downloads and runs fine on a mini2440 board. When I examine the memory I find that the memory contents starting at address 0x30080000 are unchanged which suggests that not all of the image was downloaded. If I manually modify the contents of memory at this address the memory appears to work fine. I can also perform a memory test in this region of memory with no errors, so the hardware seems okay. I tried another version of u-boot (1.3.2-mini2440) from NAND with the same results. The board is relatively new and came with WinCE installed. I have scrubbed the NAND and ran creatbbt. Perhaps there is an environment variable for u-boot I am missing or something having erased it from the NAND? U-Boot 1.1.6 (Mar 18 2010 - 15:47:48) ##### Boot for Nor Flash Main Menu ##### [1] Download u-boot or STEPLDR.nb1 or other bootloader to Nand Flash [2] Download Eboot to Nand Flash [3] Download Linux Kernel to Nand Flash [5] Download CRAMFS image to Nand Flash [6] Download YAFFS image to Nand Flash [7] Download Program (uCOS-II or Sky2440_Test) to SDRAM and Run it [8] Boot the system [9] Format the Nand Flash [0] Set the boot parameters [a] Download User Program (eg: uCOS-II or Sky2440_Test) [b] Download LOGO Picture (.bin) to Nand Flash [l] Set LCD Parameters [o] Download u-boot to Nor Flash [r] Reboot u-boot [t] Test Linux Image (zImage) [q] quit from menu Enter your selection: 7 USB host is connected. Waiting a download. Now, Downloading [ADDRESS:30000000h,TOTAL:1566726] RECEIVED FILE SIZE: 1566726 (765KB/S, 2S) ## Starting application at 0x30000000 ... At this point it hung and required a reset. Examining the memory shows the contents are correct up to address 0x3007ffff when compared to the file, but from there on is incorrect. This indicates that only the first 512k was saved to SDRAM. Sky> md 0x3007ffe0 0x40 3007ffe0: e1a06001 e24b1024 e8910003 e3a02000 .`..$.K...... .. 3007fff0: e3a035ff e2833603 eb00ee94 e1a03000 .5...6.......0.. 30080000: ffffffff ffffffff ffffffff ffffffff ................ 30080010: ffffffff ffffffff ffffffff ffffffff ................ 30080020: ffffffff ffffffff ffffffff ffffffff ................ 30080030: ffffffff ffffffff ffffffff ffffffff ................ 30080040: ffffffff ffffffff ffffffff ffffffff ................ Sky> bdinfo arch_number = 0x000000A8 env_t = 0x00000000 boot_params = 0x30000100 DRAM bank = 0x00000000 -> start = 0x30000000 -> size = 0x04000000 ethaddr = 0A:1B:2C:3D:4E:5F ip_addr = 192.168.1.6 baudrate = 115200 bps Any ideas would be appreciated? Regards, Rob
u-boot not loading entire image into SDRAM
Update: I have downloaded supervivi-128M to NAND then used it to download the image and all works well. It's just u-boot that won't download an image greater than 512K. Regards, Rob
> It's just u-boot that won't download an image greater than 512K. I have used u-boot to download kernels around 2M and JFFS2 root filesystem of up to 60M on a 64M mini2440. What format are you using for the root filesystem?
http://processors.wiki.ti.com/index.php/Put_YAFFS_Image_to_Flash Maybe, a "long-shot": "For devices with 512b block NAND the HW ECC support must be disabled in the kernel for YAFFS to work properly. For information on disabling HW ECC support please the the Disabling NAND HW ECC support page".
Thanks for the replies. There is no filesystem, and no linux, just a bootloader. I am trying to download via the bootloader (u-boot) to SDRAM, so the NAND isn't really an issue either at this point (except perhaps for any settings that might be stored there that u-boot requires). And just to be clear, the image I am trying to download is RT-Thread. U-boot won't load anything bigger than 512K, supervivi works fine. Rob
I think I now understand what you are trying to do. I recalled something to do with u-boot and magic numbers. Google turned this up. From: http://www.denx.de/wiki/DULG/UBootImages ********** 5.13. U-Boot Image Formats U-Boot operates on "image" files which can be basically anything, preceeded by a special header; see the definitions in include/image.h for details; basically, the header defines the following image properties: Target Operating System (Provisions for OpenBSD, NetBSD, FreeBSD, 4.4BSD, Linux, SVR4, Esix, Solaris, Irix, SCO, Dell, NCR, LynxOS, pSOS, QNX, RTEMS, U-Boot, ARTOS, Unity OS, Integrity; Currently supported: Linux, NetBSD, VxWorks, QNX, RTEMS, ARTOS, Unity OS, Integrity). Target CPU Architecture (Provisions for Alpha, ARM, AVR32, BlackFin, IA64, M68K, Microblaze, MIPS, MIPS64, NIOS, NIOS2, Power Architecture®, IBM S390, SuperH, Sparc, Sparc 64 Bit, Intel x86; Currently supported: ARM, AVR32, BlackFin, M68K, Microblaze, MIPS, MIPS64, NIOS, NIOS2, Power Architecture®, SuperH, Sparc, Sparc 64 Bit, Intel x86). Compression Type (Provisions for uncompressed, gzip, bzip2, lzo; Currently supported: uncompressed, gzip, bzip2, lzo). Load Address Entry Point Image Name Image Timestamp The header is marked by a special Magic Number, and both the header and the data portions of the image are secured against corruption by CRC32 checksums. ******* Good luck. Please report back as I had looked at RT-thread a year ago, but did not proceed. davef
Thanks for that Dave, however it raises more questions than it answers. DNW only adds 10 bytes to the file size (address (4 bytes), size (4 bytes), data, checksum (2 bytes). The image that does load correctly via u-boot does not contain this 64 byte header discussed at the link you posted above, nor does it start with the magic number. So why does it load correctly? What is supposed to add this header to the image? As for RT-Thread, it looks promising although it could be a little more mature for an open source project that has been in existance for 6+ years. It's biggest problem is the lack of english documentaion. I like it for it's simplicity and small footprint but does everything I need it to do. Regards, Rob
After further reading I see there is a file called mkimage which adds the u-boot image header. This is file is nowhere to be found in my toolchain, nor can I find it on the mini2440 or Sky2440 CDs. So why does it work okay for some images without this header? Why does u-boot come pre-installed on mini/sky2440 without the mkimage file on the CD? It would seem u-boot is more trouble than it is worth.I think I'll stick with supervivi. Rob
Both good questions. For the last one, maybe because they are not providing a complete build environment??
Hi Dave, Regardless of build environment, there are many images provided on the CD, non of which seem to have the u-boot header as described at the denx site. The bootloader u-boot comes pre-installed on the mini/sky2440 boards. As far as I know nobody seems to have any problem loading these images using this bootloader. There seems to be some piece of this puzzle missing. Do they provide a modified version of u-boot that does not require the header? Or does u-boot have a default behaviour in the absence of such a header? In any case, most people seem to be able to use u-boot to load the 2M linux images, 30M WinCE images and even the 50M Qtopia images without the header. So the question - why I can't load an image larger than 512K with u-boot remains. Regards, Rob
