Hi, I'm trying to compiler and transfer the PTXDist to me Mini2440 64MB and when I try to transfer through ETH apear this: mini2440:/ devinfo eth0 base : 0x00000000 size : 0x00000000 driver: none Parameters: ipaddr = 192.168.1.2 ethaddr = EA:3B:C4:98:7C:31 gateway = 192.168.1.1 netmask = 255.255.255.0 serverip = <NULL> mini2440:/ How I can obtain the serverip? Thanks
Serverip PTX Dist
Set it up in your Barebox's /env/config file. Or, if you are using DHCP, then you must tell your DHCP server to provide this IP.
Thanks Juergen, But now I have troubles with the installation in me Linux Fedora17 the FTP and DHC. Could you take some ideas about I can do it?
