Hi everyone. My boss has just handed me a device driven by a Tiny6410 without the NAND flash onboard. IT is hooked to an arcade JAMMA board and is used as the core of a device called a 138-in-1. I was handed this because I'm the only fellow here with any *nix experience. In looking at the contents of the SD card, I see the boot image on the FAT partition, and there are two linux partitions. Is there a VM or something that I can use with the linux on this card to observe the boot process? We don't have any sort of arcade machine here and I tried a VGA to DVI adapter but it didn't work.
Tiny6410 w/o NAND in arcade machine
Usually you hook up a RS232 cable (think for the 6410 a null modem cable) and run minicom on your desktop to observe the boot process. Good luck
Ah, Tiny6410 not mini6410! You will have to dig into the schematic and wire up your own DB9 connector for RS232.
What about what's on the larger board? There are a series of ports on there. What I'd like to know is why the unit reboots with any other SD card than what it came with.
> What about what's on the larger board? There are a series of ports on > there. On the mini6410? I haven't had a close look at that unit, but the mini2440 has one RS232 DB9 connector plus 3 small connectors that have TTL level signals. So, one is physically compliant with RS-232 and the other 3 need TTL to RS232 level converter chips on them or RS485 if you want. > What I'd like to know is why the unit reboots with any other SD card than > what it came with. There are a number of issues with different types of SD cards and how they are formatted. You'll have to search on this forum for solutions. Good luck!
I can post a picture of the larger board. It appears to be a keyboard matrix, CGA converter, and sound board in one.
Ah, the larger board is something special ... so I haven't a clue what is on it. Still, the tiny6410 should have the USART connections come out to a header that you could hook up a TTL to RS232 level converter to. Can JTAG be used to monitor the boot process? Never used it for anything other than re-loading the bootloader on the mini2440. There must be some easy way as I can imagine anyone being able to develop a Linux system without looking at the boot messages. There is another way ... you can pipe the boot messages to a file IF you have some way of reading the file. SD card? USB flashdrive?
Yes, it could write to the SD card couldn't it? What is strange is that when I diddle around with some of the files it just goes into a reboot loop.
The S3C6410 CPU comes with an internal ROM (called "iROM") which expects some kind of board setup software at specific sectors on the SD card. And these specific sectors depends on the SD card type. They differ if you are using an SDSC or SDHC/SDXC card. So, every card needs a special treatment to make it bootable with the S3C6410 iROM.
See if this works for you: http://www.adrive.com/ u> weedsmacker@hotmail.com p> Arcade11
Take your time, I'm a patient guy. As for the larger board here is what it has: Sound converter(also to unamplified/amplified sound for the speaker. VGA/CGA video output SD reader USB port Some sort of KBD Matrix(I think it's an IPAC clone) What do I do once I prep the SD card with that util anyway? Sorry, this isn't my forte.
Ryan, you can examine your image using the 'file' command in linux: file mmc.img Which should return this: /mmc.img: x86 boot sector; partition 1: ID=0x6, starthead 1, startsector 35, 199465 sectors; partition 2: ID=0x83, starthead 0, startsector 199500, 588000 sectors; partition 3: ID=0x83, starthead 0, startsector 787500, 686000 sectors, code offset 0x0 armed with that information you can mount the partitions and examine them on your PC (if you're using linux of course). If you examine the returned data, you will notice that there are 3 partitions listed, to mount those partitions, you're going to need to know the startsector of each partition and then multiply it by 512, that will allow you to tell the mount command what offset it needs to use to find the start of the partition. so for each partition, the offset would be: 1) 35x512, offset=offset=17920 2) 199500x512, offset=102144000 3) 787500x512, offset=403200000 you will also need to know the fs type for each partition, the first is vfat, 2nd is ext3, 3rd I am also assuming is ext3 (I haven't mounted it yet). to mount a partition, lets say the 2nd partition, you would do the following: sudo mount -oloop,rw,offset=102144000 -text3 /path/to/mmc.img /path/to/mountdir you should then be able to examine the contents of the partition but more importantly you can copy those files onto your SD card once you've recreated a similar partition structure using gparted or your favourite partitioning tool. It basically needs to avoid the first 35 sectors of the sd card and have a vfat, ext3 and ext3 partition in that order. armed with that information you should be able to recreate a partition structure on the new SD card that matches whatever it needs to boot. please bear in mind that these are rough instructions and in no way constitute a working method :) Now I come to think of it, as you have the original SD card, you can just mount that and copy them (as root) to your new SD card with the above partition layout (vfat,ext3,ext3). If you don't copy it as root you'll probably fail to copy any device nodes across and it will fail to boot.
sudo mount -oloop,rw,offset=102144000 -text3 /path/to/mmc.img /path/to/mountdir should be one single command and obviously you should change /path/to/ in each case to the path to mmc.img file and your folder that you're going to use as a mountpoint.
meh, I should think more before I hit enter!! I would also probably work on the .img file myself, just in case anything goes wrong. Lastly, when you created the image, it appears that your 2nd partition was in need of fsck, it wouldn't let me mount it initally as I had set it to mount read-only and of course linux doesn't like mounting a dirty partition.
Reggie: Thanks for your help. I really appreciate it. Here's another dilemma: When I try to modify the executable or the games listing, the system reboots. I loked and the "launcher" that runs is checking a file called SD.bin that is stored on the second partition. If there was a way to stop this it'd be amazing. I'll try recreating the card this weekend or tonight. I really appreciate your help.
You're most welcome Ryan :) I'm not sure how much more I can help, I don't have a 6410 to test anything unfortunately. Is there a flash chip on either of the boards at all? I noticed there was a file called serial.bin, if that's checking for a valid serial number, it's got to grab it from somewhere and if there isn't any nand on there then it's really got to be on a small flash/nor chip, my guess as these things are meant to be as cheap as possible that it will be a little 8pin spi flash chip, microchip or atmel probably.
Reggie: I don't think so....maybe there is maybe there isn't. I don't see one. I think ultimately they would be cranking these out as fast as they could. You can see online pictures. I can look tonight. It's looking at 3 different .bin files I think, games.bin, sn.bin, and runset.bin. Games.bin is being checked by the launcher. If the games list is changed, the system just reboots. If there was a way to figure out the format of that file then the problem would be moot.
Ok..figured this out. Ther protection is all done through a series of proprietary executables. Now it's just a matter of replacing them.
@Jurgen, I'm completely blank on this. I have the tool but what do I take from the other card to get it to work here? Sorry, I'm completely new to this stuff.
I think you can't get the old content back from the other card. With the "flashing" tool you prepare a new SD card to be able to boot a S3C64XX based board. Maybe the remaining space of the other SD card contains a filesystem where you can copy its content to the new SD card?
Ok well, it looks as though they have two different programs that checkthings, IE the serial.bin, and another file. If those can be replaced then I'd be happy. However, what I am faced with now is duplicating the card and making it boot. So far I have had no luck with a second card no matter what I do. What do I need to do/flash in order to get this other card going?
You can copy this card only for the case they are exactly the same. If they differ, you can't copy them sector by sector, as the processor's internal ROM loads the bootloader from the card depending on the sector count of the card. You only can copy the regular filesystem content and then make the new card bootable with the SD Card flashing tool.
@Juergen Is there a tutorial on how to do that? I read the page but did not have a lot of luck. This is the first time that I've ever used one of the FriendlyARM boards.
You should start with the mentioned small Windows tool to "flash" the new SD card. And see if your boards accept it (e.g. is able to boot from). Then you should read something about "partition tables" and do something on the new card similar to the old card you have.
@Juergen What do you mean? I don't have a cd or anything with this...it's just the bare board. Is there an image I need to flash that I can DL?
how did you make the copy of the sd card? it looks like it was a dd of the whole device (rather than just partitions) if that's the case, then you should be able to just dd that image to a card that is the same size or bigger.
Oh, I tried looking at the code and it seems that the only stuff that will pop out on the screen is text going through tty6. Is there a way to get a prompt on tty6 as well?
