I'm working on Tiny6410. I use a timer 0 in my program. When it comes to the Timer 0 interrupt, my code in the processor and restart from the beginning. In what could be the reason? Program with timer 0 without interrupting the installation works fine. I'm writing a function ISR address in the interrupt vector timer 0. VIC0VECTADDR =(unsigned)my_time; I'm authorize the Timer 0 interrupt executed: IntEnable=IntEnable | 0x800000; and set Timer 0 interrupt: TINT_CSTAT=TINT_CSTAT | 1; That I have not installed?
Tiny6410 interrupt of Timer
Hi, I'm trying to configure the timer0, or timer2 in my C code, but I can't compile the code because more than 100 errors appears after compilation. Please could you help me and send the timer ini code?
Hi Faust_256 I'm working on the same timer (Timer0) as you utilized in your project, but i can't come to interrupt service routine. would you mine explain more what initialization did you use for your Timer0 and your VIC?
