jffs2 Empty Flash warning - pengutronics BSP
miniarm
I am using Pengutronics BSP for mini2440. I have ported all component
(rootfs, kernel, bootloader) successfully. but before mounting I am getting
Empty flash warning.
Please check the kernel log below.
dm9000 dm9000: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
IP-Config: Complete:
     device=eth0, addr=192.168.1.156, mask=255.255.255.0, gw=192.168.1.1,
     host=192.168.1.156, domain=, nis-domain=(none),
     bootserver=192.168.1.232, rootserver=192.168.1.232, rootpath=
Empty flash at 0x0171c2ec ends at 0x0171c800
VFS: Mounted root (jffs2 filesystem) on device 31:3.
devtmpfs: mounted
Freeing init memory: 104K
As I am trying to use this board in industrual environment, will this
warning will be harmfull?
Is there any way to get rid out of this warning?
Please let me know further.
miniarm
Suggest you give us the whole boot log.  Maybe, something is wrong before
your quoted text as it all looks the same as mine . . . except I don't get
the:
Empty flash line
Juergen Beisert
Take a look:
|<---------- whole flash partition ------------->|
|<---- jffs2 image ----->|<---- still empty ---->|
If you erase the whole flash partition and then write the jffs2 image to
the flash, only a part of the empty space contains the image. What you see
is the message because JFFS2 finds the end of the image and then more
"unformatted" space behind it. You can ignore this message, as JFFS2 than
starts automatically to add the empty space the filesystem.
miniarm
@davef, @juergen,
Thank you for the time and explanation. I did the same step as mentioned in
 pdf.
Please find the complete log.
CPU: VIVT data cache, VIVT instruction cache
Machine: MINI2440
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: console=ttySAC0,115200 mini2440=1tbc
ip=192.168.1.156:192.168.1.232:192.168.1.1:255.255.255.0:::
root=/dev/mtdblock3 rootfstype=jffs2 n)
PID hash table entries: 256 (order: -2, 1024 bytes)
Memory: 64MB = 64MB total
Memory: 62144k/62144k available, 3392k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xc4800000 - 0xf6000000   ( 792 MB)
    lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc026ad0c   (2444 kB)
      .init : 0xc026b000 - 0xc0285000   ( 104 kB)
      .data : 0xc0286000 - 0xc029fd80   ( 104 kB)
       .bss : 0xc029fda4 - 0xc02b9fcc   ( 105 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:85
irq: clearing pending ext status 00000080
Calibrating delay loop... 201.52 BogoMIPS (lpj=503808)
pid_max: default: 32768 minimum: 301
devtmpfs: initialized
MINI2440: Option string mini2440=1tbc
MINI2440: LCD
 0:240x320
 [1:800x480]
 2:1024x768
 3:240x320
 4:640x480
 5:240x320
 6:320x240
 7:480x272
S3C2440: IRQ Support
S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics
DMA channel 0 at c4804000, irq 33
DMA channel 1 at c4804040, irq 34
DMA channel 2 at c4804080, irq 35
DMA channel 3 at c48040c0, irq 36
s3c24xx-pwm s3c24xx-pwm.0: tin at 98876, tdiv at 98876, tin=divclk, base 0
S3C24XX CPU Frequency driver, s3c244x cpu support
bio: create slab <bio-0> at 0
SCSI subsystem initialized
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
NetWinder Floating Point Emulator V0.97 (extended precision)
s3c-adc s3c24xx-adc: attached adc driver
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 121
io scheduler noop registered
io scheduler cfq registered (default)
s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440
console [ttySAC0] enabled
s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440
at24 0-0050: 1024 byte 24c08 EEPROM, writable, 16 bytes/write
s3c24xx-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns
s3c24xx-nand s3c2440-nand: NAND hardware ECC
s3c24xx-nand s3c2440-nand: Using flash based BBT
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V
8-bit)
4 cmdlinepart partitions found on MTD device nand
Creating 4 MTD partitions on "nand":
0x000000000000-0x000000080000 : "barebox"
0x000000080000-0x0000000e0000 : "bareboxenv"
0x0000000e0000-0x0000002e0000 : "kernel"
0x0000002e0000-0x000040000000 : "root"
s3c24xx-nand s3c2440-nand: clock idle support enabled
dm9000 Ethernet Driver, V1.31
dm9000 dm9000: eth%d: Invalid ethernet MAC address. Please set using
ifconfig
eth0: dm9000e at c487a300,c487c304 IRQ 51 MAC: a6:27:9f:53:9d:ac (random)
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
samsung-ts s3c2440-ts: driver attached, registering input device
input: S3C24XX TouchScreen as /devices/virtual/input/input0
input: pwm-beeper as
/devices/platform/s3c24xx-pwm.0/pwm-beeper/input/input1
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
cpuidle: using governor ladder
s3c-sdi s3c2440-sdi: powered down.
s3c-sdi s3c2440-sdi: mmc0 - using pio, hw SDIO IRQ
TCP cubic registered
s3c-rtc s3c2410-rtc: setting system clock to 2000-01-04 02:05:54 UTC
(946951554)
devtmpfs: mounted
init started: BusyBox v1.18.5 (2012-10-03 17:51:06 IST)
starting pid 267, tty '/dev/console': '/etc/init.d/rcS'
mounting filesystems...done.
running rc.d services...
Starting telnetd...
starting network interfaces...
ip: RTNETLINK answers: File exists
loading modules
/etc/rc.d/S99startup: line 12: /usr/bin/qt4-demo: not found
starting pid 291, tty '/dev/console': '/sbin/getty -L 115200 ttySAC0 vt100'
Here is the complete log.
I am using mini2440 1GB nand Flash. I have chosen 128M configuration in
pengutronics.
One more thing I wanted to know is How to run led program with the newer
kernel? for ex. I want to test led/pwm, linux from friendly arm comes with
the sample example. If I try to compile the same program then it gives me
ioctl error, as ioctl has been removed in newer kernel.
--ioctl error --
190:5: error: unknown field 'ioctl' specified in initializer
All my intention is to use pengutronics BSP for mini2440 and at the same
time I want to run led and pwm example from user space using ioctl method,
to turn led on/off rathar than from /sys/class interface.
Please guide me in right direction.
Thank You for your time.
akka
Dear all,
I need help from you all.
I am new and started working on board/kit (ARM9
s3c2410,smdk2410,ARM902T,64MB Flash.)
I am trying to transplant U-boot 2012.10 to this samsung s3c2410 board.
I am not able to do this.
Can you help me with any doucment how to do this.
Can you provide if you have any U-boot.bin file for this board.
Any Uboot source code modified to run on this board.
kindly help me i am struggling for one year for this.
mail id:aprakash@ueic.com
Juergen Beisert
Hard to help you with non FriendlyARM hardware...
You should ask your board vendor instead.
