Nand scrub aborted??
Kevin
cant figure out whats goin on, everything is as mentioned in all help
links, only, before i can say yes to SCRUB NAND it says SCRUB aborted.i
tried going further "nand createbbt" it also says aboorted. Y is this
happening?i have tried all the types of u-boot including that came with the
cd uboot128.bin and also compiled u boot with the code from "buserror" with
#define USE_920T_MMU
//#define CONFIG_USE_IRQ                    1  (commented)
i have a 128Mb NAND flash?Can anyone point out..
[v] Download vivi
[k] Download linux kernel
[y] Download root_yaffs image
[a] Absolute User Application
[n] Download Nboot for WinCE
[l] Download WinCE boot-logo
[w] Download WinCE NK.bin
[d] Download & Run
[z] Download zImage into RAM
[g] Boot linux from RAM
[f] Format the nand flash
[b] Boot the system
[s] Set the boot parameters
[q] Goto shell of vivi
Enter your selection: q
Supervivi> load ram 0x32000000 232696 u
Now, Downloading [ADDRESS:32000000h,TOTAL:232706]
RECEIVED FILE SIZE:  232706 (227KB/S, 1S)
Downloaded file at 0x32000000, size = 232696 bytes
Supervivi> go 0x32000000
go to 0x32000000
  argument 0 = 0x00000000
  argument 1 = 0x00000000
  argument 2 = 0x00000000
  argument 3 = 0x00000000
<0>á
U-Boot 1.3.2-mini2440 (Feb  6 2010 - 18:45:13)
I2C:   ready
DRAM:  64 MB
Flash:  2 MB
NAND:  Bad block table not found for chip 0
128 MiB
*** Warning - bad CRC or NAND, using default environment
USB:   S3C2410 USB Deviced
In:    serial
Out:   serial
Err:   serial
MAC: 08:08:11:18:12:27
Hit any key to stop autoboot:  0
MINI2440 # nand scrub
NAND scrub: device 0 whole chip
Warning: scrub option will erase all factory set bad blocks!
         There is no reliable way to recover them.
         Use this command only for testing purposes if you
         are sure of what you are doing!
Really scrub this NAND flash? <y/N>
scrub aborted
Vikas
you did not confirm on its question.
it is asking Really scrub.  So after this it is expecting you to type "y".
If you are not typing "y" or "Y" here, it will consider "N" (default) as
shown in the question.
kevin
Hi vikas thanks for the reply.
Well this is what the trouble is about. the cursor doesnt even wait for me
to press Y/y or N/n .It straight goes to say NAND scrub aborted.
is something wrong with my hardware connections??
kevin
B.P.
Hi all
I've nearly the same problem. At this point I'm typing y but nothing
happen. When I type y once again scrub aborted. Do I type any other key,
scrub aborted immediately.
andromeda
you must type y and key enter from your keyboard for confirm
B.P.
@andromeda
Thanks for that hint.
john
Maybe you press Y not y.
naresh kumar
##### FriendlyARM U-Boot(2010-11, SD) for 6410 #####
[v] Download u-boot.bin
[k] Download Linux/Android kernel
[y] Download root yaffs2 image
[a] Download Absolute User Application
[n] Download Nboot.nb0 for WinCE
[w] Download WinCE NK.nb0
[s] Set the boot parameter of Linux
[b] Boot Linux
[q] Quit to shell
NAND: 1024 MiB, RAM: 256 MiB
LCD type, firmware version: 1 1046
Enter your Selection:f
Erasing at 0x0 --   0% complete.
NAND 1GiB 3,3V 8-bit: MTD Erase failure: -5
Erasing at 0x15c20000 --  34% complete.
Erasing at 0x1a3c0000 --  41% complete.
Erasing at 0x15c20000 --  34% complete.: registered new interface driver
iuu_p
NAND 1GiB 3,3V 8-bit: MTD Erase failure: -5] Download Win
iuu_phoenix: v0.12:Infinity
Erasing at 0x1c280000 --  44% complete.x
[b
NAND 1GiB 3,3V 8-bit: MTD Erase failure: -5pan - (without firmware)1024
MiB, RAM: 256
Erasing at 0x31460000 --
s3c-nand: ECC uncorrectable error detected
OK
I am getting this problem and also could u tel me how to porting SD card
for Mini6410
