Hello FriendlyARM guys! I am extremely disappointed by the fact that you do not supply source code for 2D drivers for mini6410 despite your claim that you do. In fact the drivers provided for 2D ( 3D, JPEG, CMM ... ) are completely useless for anyone mostly because you chose not to include source code and header files that are provided lack definitions of data structures used for ioctl calls. IMHO it would be better if you would not provide any drivers at all. You can argue that there are source code for drivers on the DVD, but these apparently DO NOT match drivers actually used (and are buggy, and in general do not work at all). So to anyone trying to use 2D driver for mini6410 - make yourself a favor, write your own driver and you will save a lot of time trying to get the provided drivers to work (you will not succeed and you cannot, simply because there are no source codes provided) And for anyone needing hw accelerated 2D graphics - find a different product or you will be left on your own and will end up writing your own driver. Cheers. Bobris.
mini6410 2D driver (FIMG-2D)
For Android a complete useable solution for 2D and 3D acceleration for the S3C6410 CPU is available and completely as open source.
Really? where? Not in android kernel. Same thing as with linux, no sources, only prebuild.fo file. In any case, I assume android sources would use pmem, which is not available in linux kernel ( unless you add it there by yourself )
Take a look here: https://github.com/tom3q/openfimg
Juergen, thank you for your attempt to help, however when you have a look at the openfimg - there is no 2D driver at all there. What I am really interested in is bitblt operations to go as fast as possible. The s3c6410 processor has hardware support for this. Its documentation isn't really great, but at least something. I was hoping that there would be a driver (and there is at least some attempt for driver). What really strikes me is why there are NO SOURCES for it, and why guys from friendly arm are making it impossible to use existing driver by not providing data structures used in ioctl calls.
found some info here http://sjmt6410pm090728.googlecode.com/svn/trunk/ // // Copyright (c) Microsoft Corporation. All rights reserved. // // // Use of this source code is subject to the terms of the Microsoft end-user // license agreement (EULA) under which you licensed this SOFTWARE PRODUCT. // If you did not accept the terms of the EULA, you are not authorized to use // this source code. For a copy of the EULA, please see the LICENSE.RTF on your // install media. // // Copyright (c) Samsung Electronics. Co. LTD. All rights reserved. /*++ THIS CODE AND INFORMATION IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY AND/OR FITNESS FOR A PARTICULAR PURPOSE. Module Name: hwblt.cpp Abstract: accelerated bitblt/rectangle for S3C6410 FIMGSE-2D Functions: HWBitBlt Notes: --*/ #include "precomp.h" /** * @fn void S3C6410Disp::HWBitBlt(GpeBltParms *pBltParms) * @brief Check Further Optional processing. This is intemediate layer between display driver and 2D driver * @param pBltParms Blit Parameter Information Structure * @sa GPEBltParms * @note currently support only rotation * @note DMDO_0 = 0, DMDO_90 = 1, DMDO_180 = 2, DMDO_270 = 4 */ BOOL S3C6410Disp::HWBitBlt(GPEBltParms *pBltParms, PSURFACE_DESCRIPTOR pdescSrcSurface, PSURFACE_DESCRIPTOR pdescDstSurface) { PRECTL prclSrc; //< Src is already rotated. PRECTL prclDst; //< Dst is already rotated. RECT rectlPhySrc; //< If screen is rotated, this value has RotateRectl(prclSrc), physically addressed coordinate. RECT rectlPhyDst; //< If screen is rotated, this value has RotateRectl(prclDst), physically addressed coordinate. UINT uiSrcWidth_0; //< Source Rectangle's width as non-rotated logically. UINT uiDstWidth_0; //< Destination Rectangle's width as non-rotated logically. UINT uiSrcHeight_0; //< Source Rectangle's height as non-rotated logically. UINT uiDstHeight_0; //< Destination Rectangle's height as non-rotated logically. prclSrc = pBltParms->prclSrc; prclDst = pBltParms->prclDst; CopyRect(&rectlPhySrc, (LPRECT)prclSrc); CopyRect(&rectlPhyDst, (LPRECT)prclDst); int iRotate = DMDO_0; RotateRectlBack(prclSrc); RotateRectlBack(prclDst); /// Get Logical Aspect. uiSrcWidth_0 = ABS(prclSrc->right - prclSrc->left); uiSrcHeight_0 = ABS(prclSrc->bottom - prclSrc->top); uiDstWidth_0 = ABS(prclDst->right - prclDst->left); uiDstHeight_0 = ABS(prclDst->bottom - prclDst->top); RotateRectl(prclSrc); RotateRectl(prclDst); /// Set Relative Rotation Degree iRotate = GetRelativeDegree(pBltParms->pSrc->Rotate(), pBltParms->pDst->Rotate()); #define SWAP(x,y, _type) { _type i; i = x; x = y; y = i; } RETAILMSG(DISP_ZONE_TEMP,(TEXT("HWBitBlt Src(%d,%d)~(%d,%d):%d, Dst(%d,%d)~(%d,%d):%d, RelativeDegree:%d\n"), prclSrc->left, prclSrc->top, prclSrc->right, prclSrc->bottom, pBltParms->pSrc->Rotate(), prclDst->left, prclDst->top, prclDst->right, prclDst->bottom, pBltParms->pDst->Rotate(), iRotate)); /// if Stretch option is set, run StretchBlt /// if StretchBlt is on, but source region and destination region are same. use BitBlt if( ((pBltParms->bltFlags & BLT_STRETCH) == BLT_STRETCH) //< If it does not need to stretch or shrink. just using BitBlt is faster. && !(( uiSrcWidth_0 == uiDstWidth_0) && (uiSrcHeight_0 == uiDstHeight_0)) ) { if( (prclSrc->left < 0) || (prclSrc->right < 0) || (prclSrc->top < 0) || (prclSrc->bottom < 0) || (prclDst->left < 0) || (prclDst->right < 0) || (prclDst->top < 0) || (prclDst->bottom <0)) { /// If rotated coodinate has negative value. we can't care about when stretching is need. /// So return false, then process it by SW return FALSE; } RECTL t_rect; DWORD dwSrcWidth; DWORD dwSrcHeight; SURFACE_DESCRIPTOR descScratch; /// This is physical value == physically 0 degree; dwSrcWidth = ABS(prclSrc->right - prclSrc->left); dwSrcHeight = ABS(prclSrc->bottom - prclSrc->top); /// Set Scratch Destination Region t_rect.left = 0; t_rect.top = 0; t_rect.right = dwSrcWidth; t_rect.bottom = dwSrcHeight; RETAILMSG(DISP_ZONE_TEMP,(TEXT("t_rect,realstretch: (%d,%d)~(%d,%d), R:%d\r\n"), t_rect.left,t_rect.top,t_rect.right,t_rect.bottom, iRotate)); DumpBltParms(pBltParms); /// Set Source Surface Descriptor m_oG2D->SetSrcSurface(pdescSrcSurface); /// Check whether XY flip or not, ///if XY flip is requested, just Rotation 180 degree RotateRectlBack(prclDst); if( (prclDst->right < prclDst->left) && (prclDst->bottom < prclDst->top) ) { RotateRectl(prclDst); switch(iRotate) { case DMDO_0: iRotate = DMDO_180; break; case DMDO_90: iRotate = DMDO_270; break; case DMDO_180: iRotate = DMDO_0; break; case DMDO_270: iRotate = DMDO_90; break; } /// SWAP rect SWAP(prclDst->top, prclDst->bottom, LONG); SWAP(prclDst->left, prclDst->right, LONG); #if (G2D_STRETCH_ALGORITHM==G2D_QUARTERED_ADJUSTING) /// Adjust Coordinate from (x1,y1)~(x2,y2) to (0,0)~(x2-x1,y2-y1) /// and Recalculate BaseAddress m_oG2D->TranslateCoordinateToZero(pdescDstSurface, prclDst, pBltParms->prclClip); #endif /// Set Destination Surface to real Framebuffer Surface m_oG2D->SetDstSurface(pdescDstSurface); /// Set Destination Clipping window Rect if(pBltParms->prclClip) { m_oG2D->SetClipWindow(pBltParms->prclClip); } else { m_oG2D->SetClipWindow(prclDst); } EnterCriticalSection(&m_cs2D); #if (G2D_STRETCH_ALGORITHM==G2D_QUARTERED_ADJUSTING) m_oG2D->StretchBlt_Bilinear( prclSrc, prclDst, m_oG2D->GetRotType(iRotate)); #else m_oG2D->StretchBlt( prclSrc, prclDst, m_oG2D->GetRotType(iRotate)); #endif LeaveCriticalSection(&m_cs2D); /// Recover rect SWAP(prclDst->top, prclDst->bottom, LONG); SWAP(prclDst->left, prclDst->right, LONG); //RotateRectl(prclDst); return TRUE; } RotateRectl(prclDst); /// Reconfigure HW to set destination framebuffer address as Scratch Framebuffer /// Check mirror case, and reset region rectangle /// Doing FlipBlt from Source to Sratch /// In mirror case, source region does not change. /// only destination's regions has reverse coordinate, this cannot be negative. if(iRotate == DMDO_90 || iRotate == DMDO_270) { /// back to logical value RotateRectlBack(prclDst); /// if left-right mirror case if(prclDst->right < prclDst->left) { RotateRectl(prclDst); /// Allocation Scratch Framebuffer for Flip Operation. DDGPESurf *ScratchSurf; AllocSurface(&ScratchSurf, dwSrcWidth, dwSrcHeight, pBltParms->pDst->Format(), EGPEFormatToEDDGPEPixelFormat[pBltParms->pDst->Format()], GPE_REQUIRE_VIDEO_MEMORY); if(ScratchSurf == NULL) { RETAILMSG(DISP_ZONE_WARNING,(TEXT("Scratch Surface Allocation is failed. %d\n"), __LINE__)); #if 0//USE_PACSURF, To increase video memory is better than to use system memory as Video Surface RETAILMSG(TRUE,(TEXT("try to allocate surface usign PA Surface\r\n"))); PACSurf *ScratchSurf; #endif RETAILMSG(DISP_ZONE_WARNING,(TEXT("Maybe There's no sufficient video memory. please increase video memory\r\n"))); RETAILMSG(DISP_ZONE_WARNING,(TEXT("try to redirect to SW Emulated Bitblt\r\n"))); return FALSE; } /// Set Scratch Surface Information descScratch.dwBaseaddr = (m_VideoMemoryPhysicalBase + ScratchSurf->OffsetInVideoMemory()); RETAILMSG(DISP_ZONE_TEMP,(TEXT("ScratchBaseAddr : 0x%x\n"), descScratch.dwBaseaddr)); descScratch.dwColorMode = GetHWColorFormat(pBltParms->pDst); descScratch.dwHoriRes = dwSrcWidth; descScratch.dwVertRes = dwSrcHeight; /// Set Destination Surface to Scratch Surface m_oG2D->SetDstSurface(&descScratch); /// Set Destination Clipping window Rect m_oG2D->SetClipWindow(&t_rect); /// Set Y-axis flip flag EnterCriticalSection(&m_cs2D); m_oG2D->FlipBlt( prclSrc, &t_rect, FLIP_Y ); LeaveCriticalSection(&m_cs2D); ...stripped-down
