What are the differences between tiny6410 and mini6410. As long as kernel is concerned, I could only find machine files regarding mini6410 in arch\arm\mach-s3c64xx. Does it mean that mach-s3c64xx is fully compatible with both mini and tiny. Any comments or sharing of experience is appreciated. Vincent
tiny6410 vs mini6410
Tiny6410 and Mini6410 are both S3C6410 with the same I/O. The Tiny6410 module requires you make your own carrier board. The Tiny6410SDK includes a board the size of a 7" display and with more I/O connectors than Mini6410. Software is identical (it can be different in small ways to use added I/O of the Tiny6410SDK).
