superboot and 210s
undersys
I am trying to get superboot to work on my 210s.
I have done  the re layout step.
I have fused the superboot file to my sd card.
No matter what when I change the boot switch
I get white screen and just this printed to serial "Board type: 2"
How can I make superboot work?
Hang
I have the same problem on my 210s board.
undersys
I fixed this by using the SD card erase tool
https://www.sdcard.org/downloads/formatter_3/
Then relayout then fuse superboot.
Then copy images folder.
Works now
phuong le
i try boot android2.3.1 on mini210s detected lcd-type:w35(auto) but i use
LCD H43.so why superboot210 v1.6 not suport H43.can any share me v1.7.
Thanks !
guest
i same phuong le . why? help me problem?
Reggie
in FriendlyARM.ini make sure that the LCD=H43.
guest
i done anything that .But not support for H43 .I think zImage only support
LCD 7" .i also have tiny6410 .it's many zimage-h43,zimage-n43 .... but
mini210s only one zimage. i also try cross compile zimage but not .Why?
Reggie
try hardcoding it into the commandline option in FriendlyARM.ini for the
image you're using, lcd=H43.
guest
i confige lcd-type = H43 but it not support 4.3" :)
Reggie
no, I mean, can you add it to the Android-CommandLine ? so that it looks
like this:
Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200
init=/linuxrc androidboot.console=s3c2410_serial0 lcd=H43
guest
i also try it
it not support h43 :(
guest
dear Reggie!
You can upload files images for Android 4. and Linux on mediafire (
zImage,FriendlyArm.ini when configue H43 ) .Thanks
Reggie
No, the files are all on the friendlyarm.net ftp site, look at the bottom
of the downloads section for ftp details.
guest
Thank Reggie.
I configued success zImage (cross compile) for H43 :)
guest
hi Reggie .I have question.
Android Application development .Friendly Arm have library
hardwarecontrler.java and libhardware.so .I want more lib .Download where?
or Creat it .How?
Reggie
Not sure, I haven't done any development with android yet, I'm not even
sure what question you're actually asking me but if it's asking for missing
 modules then you probably have to install them with something like:
make modules_install
You should probably look on the android developers website
http://developer.android.com/index.html
woodromi
I have a Mini210S V1.0, H43 display board shipped with CE6 image.
I tried to install Android 4.0 on this board and get the message
yaffs2-image failed.
I tried serveral sd cards, superboot is running (Ver 1.13) and the zImage
will be installed. I downloaded latest image file from the ftp server.
I also tried to install Android 2.3.1 and Linux, same problem. I'm only
able to restore the CE6 image.
Any idea?
Reggie
use superboot, kernels and images from the same source Dvd.
woodromi
Hi Reggie,
I downloaded all images from the ftp server and used a HDsd card now.
I tried the Android 4 image from 26.07.2012 and was able to install it.
After I make a reboot I got the messages:
Board type: 2
Load Kernel...
then the board stops, no blinking or further message!
woodromi
has anybody installed android 4 on mini 210s with H43 display?
Reggie
I have no idea what to suggest, try using the the superboot/image from the
arm9home.net website, it's on a baidu server.
http://pan.baidu.com/share/link?shareid=355765&uk=959766272
http://pan.baidu.com/share/link?shareid=355946&uk=959766272
woodromi
Hi Reggie,
I fixed the problem.
My NAND is SLC type, so i changed the ini file to use the
rootfs_android-slc.img.
After this I was able to install Android with H43 on the board without
problems. The guys writing the handbook should add a comment to check the
NAND type and select the correct image file for beginners like me!
Thx for very good support!!!!!!!!!!!!!!!
Reggie
If I'd known you had a 210S with slc nand I would've suggested that.  I
didn't know there were slc boards out yet.
TheRegnirps
woodromi, how old is your board and where did you get it? They will all be
SLC in the future.
woodromi
From Fujitsu Japan.
More details this evening...
