Hello, I am trying to make a debian/emdebian rootfs for use with the default friendlyarm kernel on my micro2440. Both the mkyaffs2image tar file on this site does not work, neither does the one which came on my friendlyarm dvd. root@lina:/lina-scratch/2440-3.5/usr/sbin# ls mkyaffs2image mkyaffs2image-128M root@lina:/lina-scratch/2440-3.5/usr/sbin# ./mkyaffs2image bash: ./mkyaffs2image: No such file or directory root@lina:/lina-scratch/2440-3.5/usr/sbin# ./mkyaffs2image-128M bash: ./mkyaffs2image-128M: No such file or directory root@lina:/lina-scratch/2440-3.5/usr/sbin# ldd mkyaffs2image not a dynamic executable root@lina:/lina-scratch/2440-3.5/usr/sbin# ldd mkyaffs2image-128M not a dynamic executable these two files, are the only ones present in both tar.gzips, there are no instructions on how to use them. are these meant to be compiled or something? I have googled and found nothing. It has now been over 6 months that i have tried to get a debian rootfs working off the inbuilt flash, so I would really appreciate some help. Cheers, Seb
mkyaffs2image not working..
PS: I found and compiled another mkyaffs2image I found on the net, which does appear to build an image. However, uploading and booting that image produces the following problem: http://pastebin.com/sncpDEQ5 This is why I want to try the mkyaffs2image from friendlyarm, because I thnk they maybe have modified it for the 2440 devices, so other copies of mkyaffs2image might not work.
Say your rootfs exists at /srv/rootfs/mini6410 on your host Copy mkyaffs2image and/or mkyaffs2image-128M to /srv/rootfs cd /srv/rootfs ( Depending on your board memory choose appropriate version of mkyaffs2image ) ./mkyaffs2image-128M ./mini6410 rootfs chmod 666 rootfs Resulting rootfs can be downloaded to the target
Hi sean_h thankyou for the reply. However, this does not work. What you describe is the exact scenario I have done. lina@lina:/lina-scratch/2440-3.5-old$ ls instructions.txt mkyaffs2image-128M mkyaffs2-old rootfs_qtopia_qt4.img simple-config squeeze-grip-rootfs usbpush zImage_W35 squeeze-grip-rootfs is the rootfs for the image i want. lina@lina:/lina-scratch/2440-3.5-old$ ./mkyaffs2image-128M ./squeeze-grip-rootfs rootfs -bash: ./mkyaffs2image-128M: No such file or directory This is why I am very confused. I can SEE the file is there, using `ls`. I can 'cat' the file to see its contents. but bash says it doesnt exist.
Okay I think I just figured it out.. lina@lina:/lina-scratch/2440-3.5-old$ ld mkyaffs2image-128M ld: i386 architecture of input file `mkyaffs2image-128M' is incompatible with i386:x86-64 output For some reason bash reports the wrong error. the program has been compiled for another architecture and thus cannot be used. Is there a place I can get the source code for mkyaffs2image (specifically the -128M version) ?
Hi Sebastian The mkyaffs2image supplied by FriendlyArm is what you want. I think your problem is your rootfs. The rootfs that you have on your host must be cross compiled for your specific target. Where did you get your rootfs from? Sean
Hi Sean, I have *never* been able to make a rootfs using friendlyarm's mkyaffs2image, this is what I have been saying all along... The mkyaffs2image I found randomly on the net does actually run, and creates an image, but is not friendlyarm's copy. And that image doesn't work. I have just downloaded the friendlyarm copy minutes ago to prove that it doesnt work on this system: # this file.... http://www.friendlyarm.net/dl.php?file=linux-mkyaffs2image.tgz (linux-mkyaffs2image.tgz (16.57 KB)) lina@lina:/lina-scratch/friendlyarm/tmp$ tar xvf linux-mkyaffs2image.tgz usr/sbin/mkyaffs2image usr/sbin/mkyaffs2image-128M lina@lina:/lina-scratch/friendlyarm/tmp$ cd ./usr/sbin/ lina@lina:/lina-scratch/friendlyarm/tmp/usr/sbin$ ls mkyaffs2image mkyaffs2image-128M lina@lina:/lina-scratch/friendlyarm/tmp/usr/sbin$ ./mkyaffs2image -bash: ./mkyaffs2image: No such file or directory lina@lina:/lina-scratch/friendlyarm/tmp/usr/sbin$ ld ./mkyaffs2image ld: i386 architecture of input file `./mkyaffs2image' is incompatible with i386:x86-64 output lina@lina:/lina-scratch/friendlyarm/tmp/usr/sbin$ ./mkyaffs2image-128M -bash: ./mkyaffs2image-128M: No such file or directory lina@lina:/lina-scratch/friendlyarm/tmp/usr/sbin$ ld ./mkyaffs2image-128M ld: i386 architecture of input file `./mkyaffs2image-128M' is incompatible with i386:x86-64 output ld: error in ./mkyaffs2image-128M(.eh_frame); no .eh_frame_hdr table will be created. This is the same situation with the mkyaffs2image files on the supplied DVD. Obviously I need the source code to recompile it for my architecture. What is confusing me is that given how pretty much every PC on the planet is x86-64 by now, why did friendlyarm compile it without x86-64 support?
Sebastian I have just downloaded from your link above and run it on my machine and created a yaffs format of my rootfs. My host machine specs are: cat /proc/cpuinfo processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 42 model name : Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz stepping : 7 microcode : 0x25 cpu MHz : 800.000 cache size : 3072 KB
