USB driver
Kevin
whats with the USB driver for DWN tool??When i click on the "FriendlyARM
USB Download Driver Setup.exe" it starts installing but the text on the pop
up box is weird.Cant read except some words in english.its mostly
'?'marks.and finally it gets stuck at a pop- up dialogue box..where i have
option to click on one tab only..if i do it goes away :(..What do i do
please help if anyone had the same trouble..
thanks in advance
Did you try to run it after you clicked that one last tab?
Check your Program files for <FriendlyArm>
HTH
Kevin
thanks for the reply ..yep i have solved the matter..by searching for the
driver (after plugging in the USB cable to my PC) and not clicking the .exe
directly.silly me.
ayyap
I have executed the "FriendlyARM USB Download Driver Setup.exe" it starts
installing but the text on the pop up box is weird.Cant read except some
words in english.its mostly '?'marks.and finally it gets stuck at a pop- up
dialogue box..where i have option to click on one tab only.
I have checked the folder in program files -> friendly arm .
It was empty. I have windows xp.
Please help me to interface through usb.
Tom
You can also install the driver by hand, if you connect the board with the
PC and start from NOR. Then Windows asks for the driver.
ayyap
Hi Tom,
I tried as you said.
It installed the driver and in the device manager tab (got by right
clicking my computer-> properties ->hardware-> device manager) in the
Universal Serial Bus controllers,Friendly arm usb driver was listed .
But in the My Computer window the device was not detected.(no icon
representing arm usb was not displayed).
Tom
The device will not appear under "My Computer" - its no usb storage driver.
Its only a usb driver that is used by DNW to communicate with the board.
ayyap
Hi Tom,
It really helped.
In the DNW application the USB:OK status appeared.
I tried to transfer file in the NOR flash mode.
It was a simple .png file.It was struck in the same position without any
progress.
I have set the address to 0x30000000.
I doubt whether the files can be transfered only in Nand flash.
Please make me clear.
ayyap
hi Tom or any body,
Please add this doubt along with my previous post.
In nand flash boot mode the DNW application theUSB:OK is not found .
USB:X only is found.
Please help me.
george
The mini2440 can only communicate with DNW in NOR mode...
Read this manual:
http://www.friendlyarm.net/dl.php?file=download.pdf
ayyap
Thanks george.
I didn't worked it out since i'm away from work now.
But I believe  it will work because i had progress with the replies in this
forum.
ayyap
Hi any body,
I have downloaded an application with picture images used in that
application.
The total size is nearly 5-6Mb.
I downloaded the files one by one.
At sometimes the DNW terminal displayed <ERROR> full of the display.
Then I closed the terminal,power off the board and started the transfer
from first step and tried transfering the same file.
Now that file transfered successfully.
After downloading all the files now i powered on the board with NAND flash
mode.
Here comes the problem. The board is not booting up.
I doubt that the file size is too large and made hang to load the os in the
board.If it is so what is the remedy.
If not what is the problem and remedy.
I have communicated through hyperterminal but no use.
Please help me.
ayyap
Any body Please help me.
include the post before this i posted.
I used only the 'a' option in the bios-menu for downloading an application
which has some picture images.
Now i reinstalled the kernel,supervivi boot loader and also root image
after formatting.
Now the OS is loading. But i am in confusion how to download an user
application as i faced the problem stated in the previous post.
Please help me.
ayyap
I have done a mistake. I didn't compile the application to arm-linux-gcc.
Is this the cause?
ayyap
Please anybody help me considering the problem stated in the above
mentioned 3 posts of mine.
arunachalboy
yes u have to compile ur application using the cross toolchain.otherwise by
default it gets compiled for ur host architecture.u can run the application
on ur target board using TFTP or simply by copying it to a mmc card and
pasting it at some location in ur target board.
and ./ur-application name.
Gopalakrishna
hi my name is Gopalakrishna,i brought one friendly arm ,any body  plz  help
how to deployee  the OS  using linux-OS, the problem with dnw,ie  only for
windows environment given by friendly arm, wat about  dnw  driver for
linux....plz  help i was  deploye the OS  in windows  sucussessfully, it
was the problem in linux from dnw.
hex
DNW is a windows only application.
To upload files to vivi in linux, use the usb-push app avaliable from the
download page
http://www.friendlyarm.net/dl.php?file=usbpush.tar.gz
Naveed Asmat
Hi guys,
I have a vista on my computer and i have a same problem as stated above by
Ayyap.
"I have executed the "FriendlyARM USB Download Driver Setup.exe" it starts
dialogue box..where i have option to click on one tab only."
I tried to boot up the mini2440 board (+ 3.5 lcd) in the NOR mode but vista
windows didn;t prompt me for the usb driver. Moreover the lcd is also
blank.
Although in NAND mode the wince image works fine but couldn't install the
usb driver or can't run the DNW application or can't connect to the board
from my PC.
I will highly appreciate for any help from anyone
thanks a lot
Nav
janani ramanathan
Attachment: notworkingusb.png (367.31 KB)
hi!
  i am working on win7 with mini2440. i have first installed the usb
download driver given in downloads section, then powered on my device
connecting the usb B in device and A in pc and immediately i get a msg that
USB device not rercognized and the problem is shown in my attachment!
kindly look into it and give me your suggestion,its really important! thank
you
Gautam Ghate
Hi janani,
If you are using Win 7 (64-bit) version, you could take a look at this
post:
http://www.friendlyarm.net/forum/topic/261
Install the 64-bit USB driver and you should be good to go.
Hope that helps.
Cheers,
Gautam Ghate
dnall416
Hello
1. I am working on linux side   how can i work dnw_linux for ok6410 .
2. I want to know which is the specfic USB DRIVER FOR DNW_LINUX and how it
works.
Gautam
@dnall416:
1. The DNW utility works *only* on Windows not Linux. It simply combines
the functions of UART and USB communication with the board in a single
window. Additionally, it has menu options for downloading files over USB
for the bootloader such as Supervivi.
2. You can use the Linux minicom program for serial communication in one
terminal window. Open another terminal window and use the USBPush utility
to download files for the bootloader separately. The ZIP file on the
Download page link at "USB-Push / Boot-USB Download Tool (Linux)" contains
a small README file explaining how to do this.
Cheers!
Gautam
Dave Festing
Assume you have tried this:
http://code.google.com/p/dnw-linux/
