I'm trying to compile the latest OSELAS toolchain (2011.11.2) but I get stuck at the following error: -------------------------- target: glibc.extract.post -------------------------- pkg_patch_autogen: 'OSELAS.Toolchain-2011.11.2/patches/glibc-2.14.1/autogen.sh' /home/mc/local/OSELAS.Toolchain-2011.11.2/patches/glibc-2.14.1/autogen.sh: line 7: configure: Permission denied make: *** [/home/mc/local/OSELAS.Toolchain-2011.11.2/platform-arm-v4t-linux-gnueabi-gcc-4. 6.2-glibc-2.14.1-binutils-2.21.1a-kernel-2.6.39-sanitized/state/glibc.extract.po st] Error 1 mc@ubuntu:~/local/OSELAS.Toolchain-2011.11.2$ Any ideas how to resolve this?
OSELAS Toolchain
This line 7 contains "autoconf configure.in > configure". Do you have any strange user/group settings on your host or is the owner of your OSELAS.Toolchain-2011.11.2 directory different than the current user of the 'ptxdist' command?
I should read the documentation thoroughly! Although I'm having a problem getting my frame buffer to work. I will post again once I've done everything I can do to try and resolve it. Currently my boot logo is not displaying although all the required settings are checked (CONFIG_VT=y, CONFIG_FRAMEBUFFER_CONSOLE=y and CONFIG_LOGO=y). Also when I try to launch an application for example ts_calibrate I get a message "open fbdevice: No such file or directory"
You are using the last Mini2440 BSP? There is a bug in the framebuffer kernel driver. You need the patch from our Mini2440 website to fix it.
I am having this problem as well - permission denied. I have made sure that the OSELAS.Toolchain-2011.11.2 directory and all contents are owned/grouped by my standard user: drwxr-xr-x 10 lina lina 21 Sep 7 09:46 OSELAS.Toolchain-2011.11.2 Both the symlink and actual ptxdist program have been given the same user/group: lrwxrwxrwx 1 lina lina 44 Sep 7 08:53 /usr/local/bin/ptxdist -> /usr/local/lib/ptxdist-2012.07.0/bin/ptxdist -rwxrwxr-x 1 lina lina 58292 Jul 9 19:21 /usr/local/lib/ptxdist-2012.07.0/bin/ptxdist ...yet I still get permission denied error like bluscape. Any ideas would be appreciated.
The build has to be happend in your $HOME. Only the installation of the results will happen to "/opt" and "/usr/local". There is no need to make yourself the owner of the PTXdist files in "/usr/local/". Whenever you extract an archive in your $HOME you will be automatically the owner of all files extracted from the archive. bluescape didn't say what was wrong at his side and what exactly fixes it. I have no idea what's wrong at your side. PTXdist will create a logfile of its work. You could send it to our mailinglist.
Hi Sebastian, I resolved my problem by creating the folder for the toolchain myself and then giving myself rights to that folder: mkdir /opt/OSELAS.Toolchain-2011.11.2 chown <username> /opt/OSELAS.Toolchain-2011.11.2 chmod a+rwx /opt/OSELAS.Toolchain-2011.11.2 Juergen, Thanks, the patch fixed the problem, however, no matter what I do, the default boot logo is displayed. I've compiled my own boot logo into the kernel but it still displays the default (penguin). This is what I do to compile my own logo (maybe I'm missing something): 1.) pngtopnm logo.png | ppmquant -fs223| pnmtoplainpnm > logo_linux_clut224.ppm 2.) cp logo_linux_clut224.ppm /home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440-2012.06.0/platform-mini2440/bui ld-target/linux-3.4/drivers/video/logo 3.) ptxdist drop kernel.compile 4.) ptxdist go 5.) update kernel to Mini2440
bluescape, seems the kernel's build system simply does not recognize your own logo file. No idea why it ignores it. Take a look into the Makefile of this folder.
I am trying to use OSELAS toolchain 2016.06.1 with PTXdist 2017.03.0 and I couldn't able to build toolchain. Below is the error message that I am getting, ----------------------------- target: glibc-headers.prepare ----------------------------- configure: error: unrecognized options: --without-cvs, --with-tls, --with-__thread, --enable-hacker-mode /usr/local/lib/ptxdist-2017.03.0/rules/post/ptxd_make_world_prepare.make:12: recipe for target '/home/user/Downloads/OSELAS.Toolchain-2016.06.1/platform-x86_64-unknown-linux-g nu-gcc-5.4.0-glibc-2.23-binutils-2.26-kernel-4.6-sanitized/state/glibc-headers.p repare' failed make: *** [/home/user/Downloads/OSELAS.Toolchain-2016.06.1/platform-x86_64-unknown-linux-g nu-gcc-5.4.0-glibc-2.23-binutils-2.26-kernel-4.6-sanitized/state/glibc-headers.p repare] Error 1 Any idea why glib package is causing error?
The rules for doing this appeared to be quite complex. The date of the toolchain and PTXdist I think had to be the same to guarantee success. Are you building this for the mini2440?
Thanks davef. I am not building it for mini 2440. As you suggested, I think best thing to build toolchain with the same version of PTXdist.
Seeing as it is not for the mini2440 possibly using the latest PTXdist version and latest toolchain should be successful. I think it was OK to to use, for example, toolchain 2016.x and PTXdist 2016.y In other words, minor releases. I noticed the the gmane PTXdist website seems to have disappeared as well as the gmane mini2440 website. Possibly moved to new locations. Good luck!
For PTXdist https://www.mail-archive.com/ptxdist@pengutronix.de/ For the mini2440 https://www.mail-archive.com/oselas@community.pengutronix.de/
