Greetings. I'm starting the development with Mini2440. The main objective is develop a WebService. I don't need LCD. How I can make a rootfs linux image without graphic support (without Qtopia)? How to use the mkyaffs2image? Regards.
Make rootfs image without Qtopia
Fernando, http://wiki.iface.ch/index.php/Basic_rootfs_for_Mini2440 is a beautiful tutorial after following which you will get working rootfs with only minimalistic utilities, no graphics at all. At first, you'd better use NFS. After you successfully boot linux and get shell prompt you can build yaffs image and upload it to NAND. Run mkyaffs2image with no args and you will see that it is no brainer.
Hi. I'm following this steps and I found erros/warnings. 1) ERROR: Cannot umount 2) Warning: unable to open an initial console. Details in attached. Any tips?
> 2) Warning: unable to open an initial console. The dev/ directory in your root filesystem seems empty. Might be broken in any way?
Thanks Juergen. I don't did: $ cd ~/palha/target ~/palha/target$ sudo mkdir dev ~/palha/target$ cd dev ~/palha/target/dev$ sudo mknod console c 4 0 Now, works. I will try the next steps.
Hi. I'm following this steps and I found erros/warnings. 1) Kernel panic - not syncing: No init found. Try passing init= option to kernel. Details in attached. Any tips?
Hi. The partitions are: Creating 5 MTD partitions on "NAND 1GiB 3,3V 8-bit": 0x000000000000-0x000000040000 : "supervivi" 0x000000040000-0x000000060000 : "param" 0x000000060000-0x000000560000 : "Kernel" 0x000000560000-0x000040560000 : "root" mtd: partition "root" extends beyond the end of device "NAND 1GiB 3,3V 8-bit" -- size truncated to 0x3faa0000 0x000000000000-0x000040000000 : "nand It is a problem?
Keep your partitions in the NAND *in* the NAND. You can't use larger partitions than your real NAND device is in size.
U-Boot 1.3.2-mini2440 (Feb 24 2010 - 13:04:49)
I2C: ready
DRAM: 64 MB
Flash: 2 MB
NAND: Bad block table not found for chip 0
1024 MiB
USB: S3C2410 USB Deviced
In: serial
Out: serial
Err: serial
MAC: 08:08:11:18:12:27
MINI2440 #
MINI2440 # printenv
bootdelay=3
baudrate=115200
ethaddr=08:08:11:18:12:27
netmask=255.255.255.0
usbtty=cdc_acm
mini2440=mini2440=0tb
bootargs_init=init=/sbin/init
root_nfs=/mnt/nfs
ifconfig=ip=dhcp
${mini2440} ${root_mmc}
${mini2440} ${root_nand}
mtdids=nand0=mini2440-nand
mtdparts=mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x0050
0000(kernel),0x3faa0000(rootfs)
bootcmd=nfs 0x31000000 192.168.0.47:/home/palha/fadevel/target/uImage ;
bootm
ipaddr=192.168.0.49
serverip=192.168.0.47
bootargs=console=ttySAC0,115200 ip=192.168.0.49:192.168.0.47::255.255.255.0
root=/dev/nfs nfsroot=192.168.0.47:/home/palha/fadevel/target
partition=nand0,0
mtddevnum=0
mtddevname=u-boot
Environment size: 1269/131068 bytes
This line defines the partitions and their sizes: mtdparts=mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x0050 0000(kernel),0x3faa0000(rootfs) You should adapt it to your real NAND size. Best would be to use the '-' for the size of the (rootfs), as this will use automatically the remaining space in the NAND.
Hi Juergen. Thanks for help. Previously in u-boot, I executed the commad: #dynpart mtdparts mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x00500000(kern el),0x3faa0000(rootfs) So now, I executed the command: #setenv mtdparts mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x00500000(kern el),0x3f540000(rootfs) #saveenv But, the result is: Creating 5 MTD partitions on "NAND 1GiB 3,3V 8-bit": 0x000000000000-0x000000040000 : "supervivi" 0x000000040000-0x000000060000 : "param" 0x000000060000-0x000000560000 : "Kernel" 0x000000560000-0x000040560000 : "root" mtd: partition "root" extends beyond the end of device "NAND 1GiB 3,3V 8-bit" -- size truncated to 0x3faa0000 0x000000000000-0x000040000000 : "nand" Nothing changed. What is wrong? Why occur the Kernel panic - No init found? Regards.
As you can see, the kernel reports different partition names than the ones you have defined in the mtdparts line. Seems your kernel has compiled in this partitioning information into the kernel. You must configure a kernel without this broken "feature".
Thanks Juergen, I fixed it by modifying the file:
~/fadevel/linux-2.6.32.2$ joe arch/arm/mach-s3c2440/mach-mini2440.c
and changing:
static struct mtd_partition friendly_arm_default_nand_part[] = {
[0] = {
.name = "supervivi",
.size = 0x00040000,
.offset = 0,
[1] = {
.name = "param",
.offset = 0x00040000,
.size = 0x00020000,
[2] = {
.name = "Kernel",
.offset = 0x00060000,
.size = 0x00500000,
[3] = {
.name = "root",
.offset = 0x00560000,
.size = 0x3faa0000, //1024 * 1024 * 1024,
[4] = {
.name = "nand",
.offset = 0x00000000,
.size = 1024 * 1024 * 1024, //
The result is:
0x000000560000-0x000040000000 : "root"
But, the Kernel panic still occurs.
"Kernel panic - not syncing: No init found. Try passing init= option to
kernel."
Any tips?
Hi.
I need help to build an rootfs minimal to Mini2440.
Always the result is "Kernel panic".
MINI2440 # resetþ
I2C: ready
DRAM: 64 MB
Flash: 2 MB
1024 MiB
In: serial
Out: serial
Err: serial
dm9000 i/o: 0x20000300, id: 0x90000a46
File transfer via NFS from server 192.168.0.47; our IP address is
192.168.0.49
Filename '/home/palha/fadevel/target/uImage'.
Load address: 0x31000000
Loading: #################################################################
## Booting kernel from Legacy Image at 31000000 ...
Image Name: Linux-2.6.32.2-FriendlyARM
Created: 2012-09-05 13:31:53 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2287288 Bytes = 2.2 MB
Load Address: 30008000
Entry Point: 30008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux......
Freeing init memory: 164K
Failed to execute linuxrc. Attempting defaults...
kernel.
Regards.
Hi. The "ERROR: Cannot umount" was solved with: http://www.friendlyarm.net/forum/topic/800 (Dee) - Add IP address of mini2440 in /etc/hosts file. But, the Kernel panic still occurs.
Hey guys! Great help from this forum! What happened to the link? Its broken. I would love to take a look at it! Fernando, pelo seu nome, fala português? Me escreve pra gente trocar umas ideias se vc entender esse texto. Tks Renato
Hi, I used the Qtopia root file system downloaded from the download section of mini2440 and created jffs2 filesystem type. I dowmloaded into the mini2440 1GB board using Uboot following Bill's forum.and on boot up kernel was uncompressed and I could see the root mounted message in the minicom but with some warnings/errors. In the display I can Logo screen showing the text "Starting Qtopia, please waiting..." and stuck at that point. I have attached the minicom log along with this post. Can anybody please help me to fix this? Thanks in Advance.
Are you loading from a SD card? I recall getting errors like at the end of your attachment, but it always keep working. The "bad magic number" might be more of a worry. Search here and Bills forum for that.
Hi davef, I am not finding any post related to magic number in this forum or Bill's Forum. When I googled i saw somewhere that while creating jffs2 image we have to add the option --pad in mkfs.jffs2 command. I tried that but still it behaves the same. One more observation I am able to browse the target root file system folder hierarchy using minicom connectivity and when I went to /bin/ in the target and executed qtopia binary it showed no error and showed like it was executed and command prompt was shown in the next line. Can u please help me to fix that problem? thanks.
Sorry, I meant to say search " magic bitmask not found". I never saw the words "Expect badness" at the end. Are you using an SD card? Maybe, try another one.
Hi davef, I saw some posts reporting that SD card size greater than 1GB creating some problems. What is your advice to use which size SD card? I am using 1GB SD card now. By formatting that SD card and using it again will it help to solve the problem? My doubt still I am having is kernel,uboot are loaded into the NAND using that SD card only. I think in bootup uboot and kernel are loaded properly.Only the rootfs creating problems upto my knowledge. Is there any difference as uboot, kernel working properly if i am right and rootfs not working? Can u please let me know that? Please reply to all my queries. Thanks.
Hi davef, I retried by formatting my 1GB Sd card with FAT option and 16 KB block size. And then I copied the rootfs file to SD Card and executed the commands as in the attachment. It showed the error in minicom. I doubt I am not loading proper MMC dev:partnum. How to find the dev:partnum of the MMC attached to mini2440? Please reply!
The commands in the attachment are executed in Uboot terminal by connecting the board through minicom.
At first I formatted in Windows 7 and then I formatted in Ubuntu using as below command. sudo mkfs.vfat -I /dev/sdc And used the mmc card and connected the board thru minicom and gave the following command. MINI2440 # mmcinit mmc: Probing for SDHC ... mmc: SD 2.0 or later card found trying to detect SD Card... Manufacturer: 0x02, OEM "TM" Product name: "SA01G", revision 0.4 Serial number: 268923718 Manufacturing date: 7/2010 CRC: 0x09, b0 = 1 READ_BL_LEN=15, C_SIZE_MULT=7, C_SIZE=3437 size = 568328192 SD Card detected RCA: 0x1234 type: SD ** Partition 1 not valid on device 0 ** Where I m doing wrong? please help.
Sorry I was away. All the SD cards I ran on the mini2440 were formatted in ext4. Also, the kernel needed to re-compiled for ext4 Read the attached, it might help.
Sorry davef, The zip file you have attached was showing as corrupted when i try to extract.Can u please reattach the correct one? Thanks, Ayyappan M.
Hi davef, The content of the doc file you attached seems to be that SD card having kernel and rootfs executing from SD Card while board is running(if I am right).But I was trying to flash the NAND memory into mini2440 with SD card having rootfs file temporarily, by loading rootfs file into mini2440 SDRAM and from there write to Nand in the rootfs partition of Nand. Seems you have misunderstood my problem. Please help to fix my problem exactly.
My understanding is that the kernel is loaded into RAM and the rootfs in run on the SD card. Originally, I called this document "Booting from an SD card" and was told that was incorrect. However, my knowledge in this area is quite limited. Sorry, I don't understand how an SDcard formatted in vfat could be used in this application.
As I got into troubles while using SD card I tried tftp to flash the rootfs
image into the board. While doing that on executing the command:
MINI2440#tftp 0x31000000 rootfs.jffs2
It proceeded to load in the RAM starting from RAM Address 0x31000000.It
showed ## for many lines and at a point "32 MB was received" shown and
continued with ## printing in the command line and got blocked and hanged
at one point. The number of lines where ## were printed was nearly same
before and after "32 MB was received" line. My rootfs.jffs2 image was of
size 105.5 MB.
And in the UBoot bootup sequence in the minicom command line printed like
follows,
Welcome to minicom 2.5
OPTIONS: I18n
Compiled on May 2 2011, 00:39:27.
Port /dev/ttyUSB0
Press CTRL-A Z for help on special keys
U-Boot 1.3.2-mini2440 (Aug 18 2010 - 16:23:28)
I2C: ready
DRAM: 64 MB
NOR Flash not found. Use hardware switch and 'flinit'
Flash: 0 kB
NAND: 1024 MiB
In: serial
Out: serial
Err: serial
Loading from NAND 1GiB 3,3V 8-bit, offset 0x60000
The notable point above is DRAM:64MB.
Does this causes the problem to load the 105.5 MB rootfs file into RAM?
Is not the RAM size in 1GB mini2440 is in 128 MB bank size?
If it is 128 MB bank size then does the Uboot binary has configured DRAM as
64 MB size?
Anybody please reply to my queries.
From the product page: RAM: 64 MB, 32 bit Bus Flash: up to 1GB NAND Flash Why are you trying to load the rootfs into RAM?
Hi davef, it is done as usual.according to Bill's forum we are loading the image to RAM from there using nand write.jffs2 we will flash to nand. If there is any simple way without using RAM please let me know, my problem will be solved. Thanks.
Re-read Forrest Bao's tutorial, which sounds like exactly what you are doing. Does the OSLEAS mini2440 quickstart guide give you any clues on using TFTP and/or NFS. Another keyword is usbpush Good luck!
