building kernal linux-2.6.32.2 and get linux version 2.6.29.4
George
Hi
I downloaded the kernel linux-2.6.32.2-mini2440_20110305 and have made
configuration setup by make menuconfig then build kernel by make zImage. I
boot the mini2440 with the newly built zImage, but I got the linux version
2.6.29.4 in initial boot up
load Image of Linux...Uncompressing
done, booting the kernel.
Linux version 2.6.29.4-FriendlyARM (root@tom) (gcc version 4.3.2 (Sourcery
G++ Lite 2008q3-72) ) #3 Wed Jul 8 18:19:20 CST 2009
It seems like that kernel still remain in 2.6.29.4
How to make it update?
penguin
George,
You have to upload the image to the board. What bootloader do you use?
BTW, do not use Sourcery G++ Lite 2008q3-72 toolchain, I couldn't run
pthreds_test example built with is - use the latest from Downloads page
George
Hi Pengui,
Thanks for the advice. I actually download the zImage using supervivi
bootloader and DNW tool through USB. I have double check the gcc enviroment
setting:
# .bashrc
# User specific aliases and functions
alias rm='rm -i'
alias cp='cp -i'
alias mv='mv -i'
# Source global definitions
if [ -f /etc/bashrc ]; then
  . /etc/bashrc
fi
export PATH=$PATH:/usr/local/arm/4.3.2/opt/FriendlyARM/toolschain/4.4.3/bin
The gcc version is
arm-linux-gcc -v
Using built-in specs.
Target: arm-none-linux-gnueabi
Configured with:
/opt/FriendlyARM/mini2440/build-toolschain/working/src/gcc-4.4.3/configure
--build=i386-build_redhat-linux-gnu --host=i386-build_redhat-linux-gnu
--target=arm-none-linux-gnueabi --prefix=/opt/FriendlyARM/toolschain/4.4.3
--with-sysroot=/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi//sys-roo
t
--enable-languages=c,c++ --disable-multilib --with-arch=armv4t
--with-cpu=arm920t --with-tune=arm920t --with-float=soft
--with-pkgversion=ctng-1.6.1 --disable-sjlj-exceptions
--enable-__cxa_atexit --with-gmp=/opt/FriendlyARM/toolschain/4.4.3
--with-mpfr=/opt/FriendlyARM/toolschain/4.4.3
--with-ppl=/opt/FriendlyARM/toolschain/4.4.3
--with-cloog=/opt/FriendlyARM/toolschain/4.4.3
--with-mpc=/opt/FriendlyARM/toolschain/4.4.3
--with-local-prefix=/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi//sy
s-root
--disable-nls --enable-threads=posix --enable-symvers=gnu --enable-c99
--enable-long-long --enable-target-optspace
Thread model: posix
gcc version 4.4.3 (ctng-1.6.1)
I don't know why it shows (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72)
) in the board.
I couldn't run the pthreds_test example either. and I found this
discrepancy in version when I tried to insmod mini2440_hello_module.ko. The
module was build by linux-2.6.32.2 but kernel still in 2.6.29.4. The kernel
is linux-2.6.32.2-mini2440_20110413.tgz which is the latest and the gcc is
arm-linux-gcc-4.4.3.tgz.
Has any body experience this before
George
shravan0007
Attachment: Screenshot.png (176.17 KB)
hi,
    problem while loading kernal it is show in screen shot which i have
attached,please tell me the reason for it .
shravan
Looks like there is something wrong with your NFS setup.  You'll have to
show us the files you modified in your rootfile system.
Also, which NFS server are you running on what host? And how is that setup?
It might be helpful to read the relevant section in the QuickStart.pdf at
this site:
http://www.oselas.org/oselas/bsp/pengutronix/mini2440_bsp_en.html
shravan0007
hi ,
    i have not modified any file system was using root_qtopia_128M.img file
system
Read the link there is quite a bit to set up.
Also, I think, the bootloader has to be able to be configured for an NFS
share.  Well, barebox does.  Never used NFS with u-boot or Supervivi.
vinay
everything is working well, but i want to change text, image on startup to
required image,what i want, can anyone can guide in that area....
lsk
Did you mean you want to change that little penguin only?
Sushant
hello,
vinay: u have changes in rcS file to change text .
r@wboom
hello there,
i am new in mini2440.
i load the zimage file and kernel file on the board like supervivi,kernel
and qtopia.
now with the help of kernel guide i want to download the arm linux gcc
toolchain and linux kernel but i couldn't find on this site.
when login with ftp:// server it gives the error and couldn't find these
two.
help me.
thank you.
