Hello, Iīm trying to install Android 4 in Tiny210 SDK 7in LCD Capacitive, using the material found on DVD Tiny210-20120726.iso in FTP. I managed to write the installer on SD card and run it successfully. It boots and install a new Android on the Flash. But when booting the new OS, it hangs on screen calibration step. It doesnīt detect any touch input. I've already tried many screen setups, without success. The LCD config itself seems ok, it detects S70 panel and the image is fine. Also, when I add the skipcal parameter, it loads the OS, but without touchscreen. But the touch is configured (as displayed in calibration step) to /dev/touchscreen-1wire I donīt think that it is a hardware problem, because just before it was running the OS from factory, and touchscreen was just fine. Anyone can tell how can I change the touchscreen parameters? And which touchscreen parameter someone is using with TinySDK 7in Cap ? Thank you
Did you add the following to your INI file? I got the 1-wire driver if I omitted the ctp=1 skipcali=yes ctp=1
