There is no response for my previous post http://www.friendlyarm.net/forum/topic/4510 may i know the reason plz... Mageshwaran
no responce for my previous post....
and also for this post http://www.friendlyarm.net/forum/topic/4516 Kindly try to answer the fact...
I can imagine no response to the first post because it is a bit too general. > 1. How can I customize my led port and pin > 2. How can i record my camera and take video output by using qtopia 2.2 It depends on which kernel you are running, whether or not you are happy controlling the LED from userspace or not. Have you got /sys/class/gpio in your root filesystem? Then I'd suggest going to this page: http://www.oselas.org/oselas/bsp/pengutronix/mini2440_bsp_en.html and downloading the QuickStart.pdf and turn to section 8.4 or thereabouts. Have you read through the many posts about using the cameras. If so, ask specific questions. > Is it possible to control my lcd brightness in linux via c > program or else any method Yes. Have you got /sys/class/leds/backlight if so I will make the effort to type out the commands. > And also there is default option for that in qtopia 2.2 in the name power > management. Is it possible to get the code for that... A lot of the specific FriendlyArm modifications are closed source. Have you tried searching for <power management source code>?
I don't want to control led in user space I want to run it in kernel space kernel (2.6.38) >> Have you got /sys/class/gpio no such folder/file "gpio" >> Have you read through the many posts about using the cameras. If so, ask specific questions. Yes but various solution for CMOS camera tell the exact page that is best suited. >> Have you got /sys/class/leds/backlight if so I will make the effort to type out the commands. no such folder/file "backlight"
i have another doubt Is it support mini6410 http://www.oselas.org/oselas/bsp/pengutronix/mini2440_bsp_en.html
> I don't want to control led in user space > I want to run it in kernel space kernel (2.6.38) Why? Have you got the config file for that kernel for use with the mini2440? > Yes but various solution for CMOS camera tell the exact page that is best > suited. Sorry, I don't understand this response. > no such folder/file "backlight" This will probably stop progress. Does the config file for kernel have PWM and power management enabled in it?
Ah, mini6410. That changes everything for me as I have never worked with a mini6410. There is a BSP for mini6410 by Pengutronix.
>> If i learn to control led in kernel space there is possibilities to disturb you like this in future >> where i get this config file for mini6410 ? >> what is the output of the c-mos camera how can i take that output >> "This will probably stop progress." I can't get this...!
>> If i learn to control led in kernel space there is possibilities to disturb you like this in future You are welcome to ask questions and hope that someone with the relevant experience will try to help you. >> where i get this config file for mini6410 ? Have you got the DVD with the mini6410? Have you looked through the files on it? There should be config files for the different touchscreen types. >> what is the output of the c-mos camera how can i take that output Never worked with the camera. I would suggest you read through some of the camera threads, I recall different formats being discussed. >> "This will probably stop progress." I can't get this...! You will probably need PWM enable in order to vary the touchscreen backlight brightness. Now, you have a number of words you can try out in the <search> function at the top of the forum page.
Is it possible to develop applications with any other IDE other than ADS for mini6410? If yes what type of IDE is used..?
If you are a developer you always must know what you are doing. So, just use your favourite editor to create and modify the source files for the driver. IMHO any kind of IDE will not free you from the knowledge you need to do this job.
