KERNEL BOOT PROBLEM ON MINI6410
egemen kaleli
  I want to use kernel 2.6.38.8 which is compatible with xenomai 2.6.0.
  I added mini6410 drivers to kernel source tree from kernel 2.6.38.
  Linux 2.6.38 boots properly, but somehow 2.6.38.8 doesn't boot. Boot  is
pending as follows:
Board:   MINI6410
DRAM:    256 MB
Flash:   0 kB
NAND:    256 MB
In:      serial
Out:     serial
Err:     serial
MAC: 08:90:90:90:90:90
Hit any key to stop autoboot:  0
NAND read: device 0 offset 0x80000, size 0x500000
........................................Boot with zImage
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
     I request help about fixing this problem. I am working on this issue
for 48 hours but it is very irritating. .config files are almost same
except buzzer and  led drivers, but I dont understand why cant I port
kernel version to MINI6410. Thanks for helps in advance.
Best Regards
Egemen KALELİ
Juergen Beisert
Check what machine ID (MACH_ID) your bootloader forwards to the kernel and
what MACH_ID your kernel expects for the Mini6410.
egemen kaleli
thanks for replying;
I have looked into linux-2.6.38.8/arch/arm/tools/mach-types :
mini6410    MACH_MINI6410    MINI6410  2520
mach-id is 2520 I think.
Also U-boot prompts:
MINI6410 # bdinfo
arch_number = 0x000009D8
env_t       = 0x00000000
arch_number = 0x000009D8=2520
You see they are same. What do you suggest? I  configured the kernel with
low level debug support. I hope I can find what is going wrong.
BEST REGARDS.
Juergen Beisert
It was just an idea, because my first Mini6410 came with a u-boot which
reporst SMDK6410 as its Mach-ID. And my kernel behaves in the same way than
yours in this case. Good luck.
egemen kaleli
I am about to give up, at least I want to learn a last thing from you:
In FriendlyARM DVD, there is a precompiled u-boot_xxx.bin that I use as
bootloader. I compiled kernel 2.6.38 source with my toolchain(gcc 4.5.2)
and kernel boots and works well.
I  compiled u-boot source in DVD with my tool chain. But produced
u-boot.bin hangs even with kernel is 2.6.38:
 U-Boot 1.1.6 (Apr  6 2011 - 14:17:30) for FriendlyARM MINI6410
CPU:     S3C6410@532MHz
         Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC
Mode) X
Board:   MINI6410
DRAM:    256 MB
Flash:   0 kB
NAND:    256 MB
And doesn't go further from here. It is different problem than I asked
before because precompiled u-boot works with kernel 2.6.38. I also checked
MACH_TYPE and there is no confliction.
I had wanted o port mini6410 to Xenomai patched real-time Linux, but weird
problems discourages me.Anyway this last question is not related with this
aim but I had met this and tried precompiled uboot versions.
Juergen Beisert
You hit the problem of most of all the hardware vendors: they provide a
binary that works, and the source code to be conform with the GPL license.
But you do not really know how to get something similar to the binary from
the source they provide.
Do you know my board support package for the Mini6410? Maybe with the
u-boot from this BSP you can get your 2.6.38 kernel work. At least my BSP
provides a 2.6.39 kernel. Refer http://www.friendlyarm.net/forum/topic/3015
egemen kaleli
Finally, I solved the problem temporarily in a weird way.
I configured kernel version number as 2.6.38 and it boots now!
Vendor Uboot.bin is configured to support specific version numbers.
I looked into your bsp package tarball, but I couldn't find your u-boot.bin
or source codes. How can I get it? Does it only support kernel 2.6.39?
Best Regards.
Juergen Beisert
Take a look into the documentation and you will know how to get everything
to make you Mini6410 work.
