ipkg Pengutronix
Anyone using ipkg?  I have enabled it in the mini2440 BSP and only
installed the ipkg.conf option, but running <ipkg list_installed>
only returns a message "Successfully terminated".  No list of all the
programs I know are working on the the target :(
Both gmane sites have been down all day so have not been able to search
them for the answer.
Thanks,
Dave
Juergen Beisert
Did you try to run the 'ipkg' command from inside an NFS root filesystem?
If yes, it cannot work.
'ipkg' only works on images (like the one for the NAND memory or the one to
be copied onto an SD card) generated by PTXdist. Because in this case the
'ipkg' tool is used to install all relevant files into the image file(s).
For NFS a different mechanism is used.
Just run "ptxdist images", use the root.tgz from the
"platform-mini2440/images/" directory, deploy an SD card with this archive
content and boot your Mini2440 with this SD card (so the root filesystem is
on this SD card, when the kernel comes up). Then "ipkg list_installed" will
work as expected.
Not using NFS in this case . . . fortunately!
I am using an SD card but with root files in a ext3 partition.  So, the
procedure is to use a root.tgz image ONLY.
Thank you.
Juergen Beisert
The background is, when PTXdist runs the "go" command, the results of all
packages are:
 - used to create and fill one IPKG per package
 - copied into the root/ directory to support NFS root filesystem
When the "images" command runs, all the generated IPKGs are used to
*generate* the content of the "root.jffs2" or "root.tgz" images. And in
this case, the ipkg tool generates its database and also stores it into
these images. When you use a root filesystem based on the "root.jffs2" or
"root.tgz" content then the ipkg tool can also work at runtime on your
target machine.
Due to the fact the root/ directory content intended for the NFS root
filesystem is just "copied" (due to permission restrictions), there is no
ipkg database available. That is why ipkg cannot work in NFS root
filesystem based on the PTXdist generated root/ directory.
OK . . . if I had chosen to run the rootfs on NAND I would have got the
ipkg information as well.
It worked properly, so now I have a complete list of all the applications
that can run on the target.
Cheers,
