RFT-230-2
Mohammad Etedali
Attachment: big_4709654.jpg (3.16 KB)
i have RFT-230-2 (USB Port)
How do I install this in Windows CE 6
NothinRandom
Hi Mohammad,
The easiest way that I've gotten a RFID to work with Mini2440/6410/210 is
to use the one from sparkfun, which operates over serial TTL. If you're
ambitious and know how to do PCB layout, then go with this route:
https://www.sparkfun.com/products/8709. Else, go with this option:
https://www.sparkfun.com/products/9875. The only modification that I would
suggest is to step the serial output voltage from 5V down to 3.3V using a
simple voltage divider.
laurent
don't know where you are from, but you may be interested in this :
http://www.tritechbelgium.com/shop/category.php?id_category=33
The usb are easy to get to work as its a simple usb keyboard emulation, but
they are read-only. The i2c module is read/write, but you must have i2c
working on your mini. Here is a page with a small video demonstrating the
i2c module :
http://www.tritechbelgium.com/content/mini2440-gpio-interface-board
Good luck,
Laurent
Alen
hi.
i can Request, Anticoll, Select and LoadKeyFromEE but in Authentication i
have problem. this is my code. help me please. thanks.
        MiFareAPIClass.MF_Request(0, 0, MiFareClass.cardT(0))
        MiFareAPIClass.MF_Anticoll(0, MiFareClass.cardSN(0))
        MiFareAPIClass.MF_Select(0, MiFareClass.cardSN(0))
        MiFareAPIClass.MF_Halt(0)
        MiFareAPIClass.MF_LoadKeyFromEE(0, 0, 0)
        MiFareAPIClass.MF_Authentication(0, 0, 0, MiFareClass.cardSN(0))
alireataghizadeh
hi i buy a device by serial number 1306250108
this  is a rfid  model rft-230-2(0)
i cant any work whit this device, please have me an application that works
whit this divice, i want use this divice in my program that i write it whit
  c#
please help me
hossein daneshnia
i ned driver Rft203-2(0)
for windows server2012
thanks
