Hi all, I try to set up a wireless connection on my Mini2440 with kernel 3.4 and OSELAS BSP. As USB sticks i have TP-Link WN721N and WN821N. I activated the Atheros ath9 driver and build in the kernel the firmware blobs htc_9271.fw and htc_7010.fw preventing them from being build (got no source for the firmware). I also activated LED features and so on for this and also many other wireless drivers. When i plug in the stick i got this response: usb 1-1.3: new full-speed USB device number 4 using s3c2410-ohci usb 1-1.3: not running at top speed; connect to a high speed hub usb 1-1.3: New USB device found, idVendor=0cf3, idProduct=9271 usb 1-1.3: New USB device strings: Mfr=16, Product=32, SerialNumber=48 usb 1-1.3: Product: USB2.0 WLAN usb 1-1.3: Manufacturer: ATHEROS usb 1-1.3: SerialNumber: 12345 usb 1-1.3: ath9k_htc: Firmware htc_9271.fw requested usb 1-1.3: ath9k_htc: Transferred FW: htc_9271.fw, size: 51272 ath9k_htc 1-1.3:1.0: ath9k_htc: HTC initialized with 33 credits ath9k_htc 1-1.3:1.0: ath9k_htc: FW Version: 1.3 ieee80211 phy3: Atheros AR9271 Rev:1 Looks good to me so far. wpa_supplicant.conf: network={ ssid="caro" key_mgmt=NONE wep_key0=510C78B...and so on ;-) wep_tx_keyidx=0 priority=5 } When i try the command: wpa_supplicant -D wext -i wlan0 -c /etc/wpa_supplicant.conf i get the answer: rfkill: Cannot open RFKILL control device ADDRCONF(NETDEV_UP): wlan0: link is not ready When entering the following: ifconfig wlan0 192.168.0.50 up wpa_supplicant -D wext -i wlan0 -c /etc/wpa_supplicant.conf only: rfkill: Cannot open RFKILL control device I tried to enable RFKILL in the kernel (/proc/config.gz says it is not enabled), but could not find an option or flag for it in the kernel menu. When i manually enable it in the kernels .config (CONFIG_RFKILL=y) it would be overwritten during compiling. So what i do wrong and how can i solve this? The firmware blobs are from http://git.kernel.org/?p=linux/kernel/git/firmware/linux-firmware.git. Are they byte code or native code for the sticks controller. I wonder not to find any source code for it. I read a lot in the web but can't find how to enable rfkill or solve my problem in another way. Thanks in advance, Titus
Pengutronix BSP Mini2440 and wpa_supplicant
Run the "ptxdist kernelconfig" and enter the '/' char, then enter RFKILL and the kernel dialogue will show you where RFKILL is located. Seems it is some GPIO or switch which can enable/disable the receiver/transmitter.
Hi Juergen, thank you! Yes, it is a GPIO. It is located under Networking support - RF switch subsystem support - GPIO RFKILL Additionally i have to enable Broadcom BF43xx Support, i don't know why, but have read that in internet. And also i don't know understand why the stick acts under wlan2 where wlan0 and wlan1 has no devices, but it works now for TP-Link WN721N and WN821N ;-) Good night, Titus
