plz help me on the following error I have followed the steps given in OSELAS Quickstart for FriendlyARM Mini2440 ------------------------------ target: pkg-config-0.25.tar.gz ------------------------------ --2012-08-02 23:04:21-- http://pkgconfig.freedesktop.org/releases/pkg-config-0.25.tar.gz Resolving pkgconfig.freedesktop.org... 131.252.210.176 Connecting to pkgconfig.freedesktop.org|131.252.210.176|:80... failed: Connection timed out. Retrying. --2012-08-02 23:04:47-- (try: 2) http://pkgconfig.freedesktop.org/releases/pkg-config-0.25.tar.gz Connecting to pkgconfig.freedesktop.org|131.252.210.176|:80... failed: Connection timed out. Retrying. --2012-08-02 23:05:10-- (try: 3) http://pkgconfig.freedesktop.org/releases/pkg-config-0.25.tar.gz Connecting to pkgconfig.freedesktop.org|131.252.210.176|:80... failed: Connection timed out. Retrying. --2012-08-02 23:05:34-- (try: 4) http://pkgconfig.freedesktop.org/releases/pkg-config-0.25.tar.gz Connecting to pkgconfig.freedesktop.org|131.252.210.176|:80... failed: Connection timed out. Retrying. --2012-08-02 23:05:59-- (try: 5) http://pkgconfig.freedesktop.org/releases/pkg-config-0.25.tar.gz Connecting to pkgconfig.freedesktop.org|131.252.210.176|:80... failed: Connection timed out. Giving up. --2012-08-02 23:06:20-- http://www.pengutronix.de/software/ptxdist/temporary-src/pkg-config-0.25... Resolving www.pengutronix.de... 78.47.139.85, 2a01:4f8:121:2:5054:ff:feaf:fc62 Connecting to www.pengutronix.de|78.47.139.85|:80... connected. HTTP request sent, awaiting response... 404 Not Found 2012-08-02 23:06:26 ERROR 404: Not Found. Could not download packet URL: http://pkgconfig.freedesktop.org/releases/pkg-config-0.25.tar.gz make: *** [/home/dhruv/OSELAS.BSP-Pengutronix-Mini2440-2012.06.0/src/pkg-config-0.25.tar.g z] Error 1 dhruv@dhruv-laptop:~/OSELAS.BSP-Pengutronix-Mini2440-2012.06.0$
Ptxdist: Error during BSP Mini2440-2012.06.0 installation.
i cud fix this error by manually downloading pkg-config-0.25.tar.gz file n placin that in OSELAS.BSP-Pengutronix-Mini2440-2012.06.0/src/ folder
Now i am getting the following error, plz help me on it, asap; checking whether to build gtk-doc documentation... no checking for xsltproc... /usr/bin/xsltproc checking for library containing clock_gettime... -lrt checking for BLKID... no configure: error: Package requirements (blkid >= 2.20) were not met: Requested 'blkid >= 2.20' but version of blkid is 2.19.0 Consider adjusting the PKG_CONFIG_PATH environment variable if you installed software in a non-standard prefix. Alternatively, you may set the environment variables BLKID_CFLAGS and BLKID_LIBS to avoid the need to call pkg-config. See the pkg-config man page for more details. make: *** [/home/dhruv/OSELAS.BSP-Pengutronix-Mini2440-2012.06.0/platform-mini2440/state/u dev.prepare] Error 1 dhruv@dhruv-laptop:~/OSELAS.BSP-Pengutronix-Mini2440-2012.06.0$
I tried to update blkid with # sudo apt-get update # sudo apt-get install libblkid-dev still getting the same error plz help me..
dhruv: I did the same here. Extracting the "OSELAS.BSP-Pengutronix-Mini2440-2012.06.0" and building it with PTXdist-2012.06.0. $ ptxdist preapre udev [...] checking whether to build gtk-doc documentation... no checking for xsltproc... /usr/bin/xsltproc checking for library containing clock_gettime... -lrt checking for BLKID... yes [...] So, I have no idea what's going wrong at your side. Prior configuring the "udev" package PTXdist has built the "libblkid" package. All dependencies should be fulfilled.
Ahh, maybe I know what you have done! Did you start to build this "OSELAS.BSP-Pengutronix-Mini2440-2012.06.0" with "ptxdist-2011.11.0", stop it and then continue with "ptxdist-2012.06.0" to finalize the build? "ptxdist-2011.11.0" defines the 2.19.0 version for the libblkid package, while later PTXdist versions define 2.20. And the newer "udev" from the "ptxdist-2012.06.0" stumbles over the older (already built) libblkid from the "ptxdist-2011.11.0". You should re-build everything in the BSP when you change the ptxdist version for this BSP project. Just ensure you are using "ptxdist-2012-06-0" and run a "ptxdist clean; ptxdist go" in your Mini2440 BSP project. Then all parts will be consistent with the new PTXdist version.
Juergen thanks , i could generate the images by following the as u directed to. I have a doubt? how can i verify that the kernel if configured for w35 LCD (though i had specified 6tbc in bootarg: configs/platform-friendlyarm-mini2440/barebox-128m-env/config)
Take a look into the kernel messages ("dmesg" command). It will report which screen parameter it is using. Please note: There is a bug in the "OSELAS.BSP-Pengutronix-Mini2440-2012.06.0" which prevents all supported LCDs from working. You must apply the hot-fix[1] to the Mini2440 BSP and then rebuild the kernel to make it work again. [1] http://www.pengutronix.de/oselas/bsp/pengutronix/download/OSELAS.BSP-Pen...
