Problem with ubuntu sd boot
Ashwin
I just installed the Ubuntu on Nand and i made the Ubuntu SD boot for my
mini6410. I created two partition one with Fat32 and second partition as
EXT2. I placed the kernel on first partition and rootfs on second
partition. While booting from my sd i didn't get the xfce window screen..
Instead it open a Terminal console..
How to get xfce window on SD boot?
Ashwin
ThomasM
adding startxfce4 in the ~/.bashrc? I'm not sure but should work normally.
Ashwin
my problem is solved by placing the roofs in ext3 partition insteed of ext2
partition. now Ubuntu SD boot is working perfectly.
My first partition is fat and it contains the zimage and friendlyarm.ini
files. second partition is EXT3 which contain rootfs.
Ashwin
