Hi, Is it possible to use LCD connector as GPIO, If yes, is there any drawback of using LCD interface as GPIO? because I found GPC and GPD on same interface. @davef, could you please guide me on this...? Look forward to hear from you soon.
Possible?
From someone who has just got GPIO, ADC and SPI working on a ATmega32U4 board that I plug into the mini2440 USB port :) From my limited understanding it appears you can use those ports for GPIO. They appear to have the same functionality as other GPIO ports. A rough count gives about 20 GPIO available on the GPIO connector. Do you need more than that?
@davef, yes I am driving one card that is having 38 gpio, so I will need more than 20 GPIO and I want it on same Bank. I found GPD is on the same bank and I can operate 16 IO at once. Could you please tell me timer resolution for the GPIO? i.e. what time it require to operate 16 GPIO at once...? -- tinyarm
Could you please tell me timer resolution for the GPIO? i.e. what time it require to operate 16 GPIO at once...? User space GPIO access I believe is limited by the system timer. Think that can be reduced to something like 1ms. 16 GPIO, I'd guess up to 50ms. If you write a kernel driver I believe you can make things happen a lot faster. Haven't tried myself. I have only used GPIO from user space (sysfs) and was seeing delays of several ms. I did some research on trying to make a 5-10MHz DSO on this platform and gave up. Have you looked at SDIO (on the mini2440) and what it might offer?
