Hello friends,
I am new to this forum and also to linux.
I am facing a problem with the I2C lines present on CON4. Actually i am
interfacing an ADC externally to this lines; i don't know how to access
this lines i have used i2c-tools and the output of the i2cdetect command is
as below:
[root@FriendlyARM /]# i2cdetect -r 0
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c/0 using read byte commands.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 51 52 53 -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
it is showing my ADC at 0x68; i have rechecked it by disconnecting my ADC
from the board after that this command doesn't show any device on 0x68 it
is marked empty.
I have read linux documentations for I2C and using ioctl for passing
address but there itself it shows error.
can some one please provide me a sample code for using I2C for an external
device connected on mini2440 it would be very helpful thanks in advance...
Help regarding I2C lines on CON4 of mini2440
Hi there, I created a JNI for use with Android that uses I2C on a Mini6410 but the code should help you figure out how it works. Try here https://sourceforge.net/projects/mini6410-i2c/ Dave...
@ Dave McLaughlin Hey thank you so much for the code just 1 doubt i am also using the same ADC as you are how to pass the read and write address the datasheet of MCP3424 says write address is 0b11010000 and read address is 0b11010001 so how do you pass this address this has been a headache for me now... It would be helpfull if you can clear my doubts regarding this... Thanx in advance....:-D
Do we need to rebuild the kernel for enabling the I2C lines of CON4 as the MINI_2440_USER_MANUAL says that this pins are all GPIO, but they are marked as special function interfaces. They can be configured for other purposes too by setting related CPU registers. What does this mean..?? Please Help me...!!
Hi I have the same problem with COM4 connector and I2C bus. Connecting expaner PCF 8574 at SDA and SCL to COM4 does not work. When you connect the SDA and SCL pins EEPROM AT24C08 for detecting it without any problems. I tried with and without the resistor pullapp him. I think you have to turn in the Linux kernel How do i2c activation in COM4? Please help me !
Hi Ketul, The address is used by shifting it 1 bit to the right from the datasheet. Bit 0 is the read and write bit of the I2C protocol. 0x68 is the result of this shift. I have to admit, when switching from programming microcontrollers to using Linux drivers this part confused me at first too. Email me and I will send you the Java code I use to read the MCP3424 It will help to understand how this works. dave AT axoninstruments DOT biz Cheers. Dave...
