Just got my Tiny210 with the 7" Capacitive LCD, having a problem when reinstalling android from SD it comes to the touch calibration screen. But the touch screen does not respond, the options in the boot file arë: CheckOneButton=No Action = Install OS =Android LCD-Mode = No LCD-Type = S70 LowFormat = Yes VerifyNandWrite = No CheckCRC32=No StatusType = Beeper | LED ################### Android 4.0.3 #################### Android-BootLoader = Superboot210.bin Android-Kernel = Android/zImage Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc androidboot.console=ttySAC0 skipcali=yes ctp=1 Android-RootFs-InstallImage = Android/rootfs_android.img When superboot is running it says the Touch device is 1-wire. Any help is greatly received. Phil
Tiny210 with 7" Capacitive LCD
Hey Phil. Are you still in China? (Charlie). Was it needing S700 for LCD type and Kernel? I have not had to reload one yet.
What was your solution to this? I've checked in the manual but apparently I'm missing it. I have the same issue you were having with the capacitive touch and the calibration screen. Let me know. Thank you!
All right, I've gotten past the calibration screen by adding this in the FriendlyArm.ini -- "skipcali=yes" on the line for Android-CommandLine.
Hi Charlie As Nomad said just had to put the "skipcali=yes" in the Android command line. Should have "RTFM" or "Read The Friendlyarm Manual" !! Still in China, now working on integrating Z-Wave into the Tiny210. Phil
Cool. Long time no hear. I was in Guangzhou and Shenzhen for a couple weeks last Spring. I didn't think to try to reach you. I have not tried it, but I wonder if LCD-Type=S700 will work? It is the FA name for that screen.
Hi, I am trying to use the 7" capacitive LCD with qt2.2. I added "skipcali=yes cpt=1" to the Linux init line, but I can't get the touch screen to work, any advice? Dov
Heard the same thing from someone yesterday. Android supports, working on the Linux/Qtopia (kernel driver needed no doubt).
Hello guys, When I use skipcali=yes, I can pass the calibration and boot the OS, but the touch doesn´t work. I already tried with ctp=1 (does it stand for capacitive touch panel?) could someone share your FriendlyARM.ini that is working for Tiny210 SKD 1 with Capacitive 7in LCD ? Thank you
tiny210V2SDK with 7" screen touch not working: After trying a lot to get the original android working after a reflash I found the relevant information inside of the manual. The "ctp=" command line options selects the touch controller hardware. It looks like there are different boards with different touch controller out there. Mine came with FT5304. So instead of using "ctp=1" like in the sample from friendlyarm I had to use "ctp=3" (this works for android only, see comment below),: ctp=0 ==> N/A ctp=1 ==> 7" touch with GT80X touch controller ctp=2 ==> 4.3" touch with FT5306 touch controller ctp=3 ==> 7" touch with FT5406 touch controller To get the linux images to work you also have to compile/add the correct kernel module (which is present in the android image only). More details here: http://www.friendlyarm.net/forum/topic/4678 Maik
if you look in the kernel sources, in arch/arm/mach-s5pv210/mini210-lcds.c,
you'll find this:
/* Try to guess LCD panel by kernel command line, or
* using *W50* as default */
static struct {
char *name;
struct s3cfb_lcd *lcd;
int ctp;
} mini210_lcd_config[] = {
{ "W50", &wvga_w50, 0 },
{ "A70", &wvga_a70, 0 },
{ "S70", &wvga_s70, 1 },
{ "H43", &wvga_h43, 1 },
{ "A97", &wvga_a97, 0 },
{ "L80", &wvga_l80, 0 },
{ "G10", &wvga_g10, 0 },
{ "A56", &wvga_a56, 0 },
{ "W101", &wvga_w101, 0 },
{ "W35", &wvga_w35, 0 },
{ "HDM", &hdmi_def, 0 }, /* Pls keep it at last */
the 3rd value in the struct is used to set ctp and the valid controllers
are as Maik says, if you look in
arch/arm/plat-samsung/include/plat/ctouch.h you will see:
enum {
CTP_NONE = 0,
CTP_GT80X,
CTP_FT5306,
CTP_FT5406,
CTP_MAX
More system update details, please see our website, it is the english version: http://armdevs.com/doc/fa210/info252.html
@armdevs.com Do you what to do if I'm running CE6 with 4.3" capacitive touchscreen on a mini210s? Mine just doesn't want to cooperate at all! Thanks!
When my tablet with the capacitive toushcreen starts the touch coordinates are backwards and dont cover the entire screen. Only the bottom left side of the screen shows touches and they are displayed towards the middle upper side (unless I touch the middle upper side then they show up in the bottom left). How can I kick off the proper calibration routine for the capacitive touchscreen?
plug a usb mouse or keyboard into the system and run the itest app., then look for 'recalibrate' in the list and run it. Now reboot (power cycle) the mini210s/Tiny210, the recalibrate option will remove a couple of settings that allow the system to run ts_calibrate when you've rebooted, before you get the android text on screen. Once you've successfully calibrated the screen it will finish up booting android.
That didnt work unfortunately. The reboot doesnt start the calibration utility. Part of the installation instructions specifically for the capacitive touchscreen is to set skipcali=yes as part of the commandline so that calibration is skipped. I wonder if there is a kernel option for the capacitive touchscreen.
coming back to this, I'm not entirely sure how all of the touchscreen stuff is setup, running ICS, I don't see any ts_calibrate files etc. I can see them just fine on android 2.3 and a mini6410, that procedure I mentioned works, if I remove skipcali on my mini210s, it breaks my kernel with ts_config errors.
Same here. I cant boot if skipcali is removed but yet I cant calibrate the touchscreen without a calibration routine.
I've just hacked up my drivers to work in android 4.0.3, not sure if the same things apply here or not as it's a resistive touch screen, see here for more details: http://www.friendlyarm.net/forum/topic/4895
Something very odd just happened. My contact at friendlyarm had me try ctp=1 since its also for a 7" tablet but the touchscreen wouldnt respond at all for that so I put it back to ctp=3 and reflashed and now the touchscreen is fully working. I havent done anything differently (same SD card as before with the same images on it).
I guess it depends on which FT touchscreen you have? or is yours goodix? If you look at the above mini210_lcd_config[] array, you can see that there are only 2 screens marked with ctp value being 1? I wonder if you have to find your lcd in the list S70,A70? and change the value from 0 to 1 or even 3? It feels like the code can go off and check those values against the screen but it's also capable of pulling the ctp info from the cmdline, so I'm not entirely sure what's going on there. I do know that ts and lcd drivers all seem to have some kind of loose inter-dependency due to #defines for picking up the various touchscreens, which can end up breaking the drivers if you turn the wrong driver off in the menuconfig.
included only one ini file the FriendlyARM on images folder no files in root diretory and use skipcali=yes and correct lcd size ctp
i used ctp=3 as well as ctp=1 also,my lcd size is 7 inch but my board is not calibrating , the cross point is not responding..someone plz help
CheckOneButton=No Action = Install OS =Android when i used the Android-RootFs-InstallImage = Android/rootfs_android.img the update was un-successfull but when i used Android-RootFs-InstallImage = Android2.3.1/rootfs_android-mlc2.img the update was successful but the screen is not responding to calibration LCD-Mode = No LCD-Type = S70 LowFormat = Yes VerifyNandWrite = No CheckCRC32=No StatusType = Beeper | LED ################### Android 4.0.3 #################### Android-BootLoader = Superboot210.bin Android-Kernel = Android/zImage Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc androidboot.console=ttySAC0 skipcali=No ctp=3 Android-RootFs-InstallImage = Android/rootfs_android.img When superboot is running it says the Touch device is 1-wire. Any help is greatly admired.
skipcali=yes ctp=2 Worked finally, after 10-15 flashes with different paramenters, find this thread. Thanks!
When you want to run your board with a capacitive LCD you need to specify “skipcali=yes” and “ctp=n”. The value “n” can be either 0 or 1, 2, and 3. If n=0 it means no capacitive LCD will be connected. If n=1 it means a GT80X based 7’ capacitve touch panel will be connected. If n=2 it means a FT5206 based 7” capacitive touch panel will be connected. If n=3 it means a FT5406 based 7” capacitive touch panel will be connected.
