uart example
masood nooryan
Attachment: Uart example.rar (5.3 MB)
hello to all
for long time I search the mini2440 examples and specially I wanted no os
codes.
when I found 2440test codes, it help me to modify and write desired codes
for uart, key , ...
in this topic I bring uart example that recieve an character from computer
and transmit some informations by uart. there several notes that shoulde be
considered :
1- Uart configuration is : baud rate:115200 , 8 data bit, no parity bit, 1
stop bit.
therefore we must set these above configuration in terminal program such as
hyperterminal or codevision or aspmon programs.
2- for rs232 (Uart0) we must control RTS/CTS manually and therefor must set
handshaking in above terminal programs to "none" .
3- a lot of functions that used in main is defined in 2440lib.c file.
if anybody has any question about the uart example mail me.
best regards
praveen
i want to get a data from uart1 and see this data in uart0(on hyperterminal
screen )so can u plz send me a code for that...
praveen
and i am using keil microvision with out os
