Angstrom - boot options 0tb
Tomasz_K
Attachment: start 0t.txt (8.29 KB)
Hello
I have a module mini2440 fired from the MMC distributions Angstrom:
U-Boot 1.3.2-mini2440 (Feb 24 2010 - 13:04:49)
I2C:   ready
DRAM:  64 MB
Flash:  2 MB
NAND:  256 MiB
USB:   S3C2410 USB Deviced
In:    serial
Out:   serial
Err:   serial
MAC: 08:08:11:18:12:27
Hit any key to stop autoboot:  0
mmc: Probing for SDHC ...
mmc: SD 2.0 or later card found
trying to detect SD Card...
Manufacturer:       0x03, OEM "SD"
Product name:       "SU08G", revision 8.0
Serial number:      280664915
Manufacturing date: 8/2011
CRC:                0x3f, b0 = 1
READ_BL_LEN=15, C_SIZE_MULT=0, C_SIZE=365
size = 0
SD Card detected RCA: 0xe624 type: SDHC
2155084 bytes read
## Booting kernel from Legacy Image at 31000000 ...
   Image Name:   Angstrom/2.6.31+git/mini2440
   Created:      2010-11-23  13:50:27 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2155020 Bytes =  2.1 MB
   Load Address: 30008000
   Entry Point:  30008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
done, booting the kernel.
Linux version 2.6.31.1 (koen@dominion) (gcc version 4.3.3 (GCC) ) #1 Tue
Nov 23 14:50:12 CET 2010
CPU: VIVT data cache, VIVT instruction cache
Machine: MINI2440
CPU S3C2440A (id 0x32440001)
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: console=ttySAC0,115200 rootfstype=ext3
root=/dev/mmcblk0p3 rw rootwait bootdelay=3 mini2440=0tb
PID hash table entries: 256 (order: 8, 1024 bytes)
Memory: 64MB = 64MB total
Memory: 60408KB available (3820K code, 412K data, 120K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:85
irq: clearing pending status 02000000
console [ttySAC0] enabled
MINI2440: Option string mini2440=0tb
MINI2440: LCD [0:240x320] 1:800x480 2:1024x768
TCP cubic registered
s3c2440-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz).
lib80211: common routines for IEEE802.11 drivers
s3c2410-rtc s3c2410-rtc: setting system clock to 2012-07-22 07:06:40 UTC
(1342940800)
Waiting for root device /dev/mmcblk0p3...
s3c2440-sdi s3c2440-sdi: powered down.
mmc0: error -110 whilst initialising SD card
bootargs console=ttySAC0,115200 rootfstype=ext3 root=/dev/mmcblk0p3 rw
I have LCD "W35"
Can someone help me?
PS.
I can not compile from source distribution.
dlatego korzystam z Narcissus.
