Ubuntu for Tiny210
Tran Anh Tuan
Hi everybody,
I have a Tiny210 board with specs:
- MPU: Samsung S5PV210 Cortex A8
- Flash: 256MB NAND
- Ram: 512MB
- LCD: S70, 7inch
(more info: http://www.friendlyarm.net/products/tiny210)
...and it is allready installed Android OS. Now, I want to build an Ubuntu
(download from ubuntu site) to Ubuntu image for install to board VIA TF
card. Please guide me what to do? step by step?
Thanks a lot in advance!
Pawel
basicly - log in on friendly arm ftp and download it. On this FTP you can
find rootfs for ubuntu 12.04. There is also a chinese readme which can be
easily translated to english using google translate.
Alonso
Hi.
Can anyone give me a compiled image of ubuntu?
I tried to compilate it, and fail. Can anyone help me?
Reggie
http://armworks.cc/index.php?title=Mini210S_ubuntu_sd
Alonso
Hi. Thanks. I have complied it and it run!!! :)
Can you say me the sudo pass?, "fa" is not sudder user.
Thanks!!!
Reggie
you have to add fa to /etc/sudoers :)
Alonso
Hi. It works xD
Alonso
Hi, Have you solved the touch screen? I cant make it run.
Thanks!!!!
Kevin Lambert
I have a Tiny210v2 and followed the linked directions but all I end up with
is a white screen when I reboot and no debug.  What did you do differently
than the directions for your Tiny210?
praveen
Hi, Alonso
I am working on tiny210v2 ,I am able to port Ubuntu but its Capacitive
touch-screen is not working in Ubuntu but it is working in Qtopia....
please help!!!
Marco
I'm running Debian Squeeze on tiny210v2 but I can not in any way to run the
touch screen..
I have a 7" lcd capacitive touch with focaltech ft5x06 controllers.
I compiled 2.6.35.7 kernel and added support for the driver ft5x06.
Now I got a /dev/input/event0 that returns values ​​when I
touch the screen, but ts_lib not work :(
I set "raw_input = friendlyarm-ts-input" and executed ts_print and
ts_calibrate but I always get a segmentation_fault..
Where is the correct friendlyarm-ts-input binary ?
greetings from Italy
uelman
hello,
how do I put ubuntu 12.04 on my tiny210v2. Please I need help. The steps to
install ubuntu is not equal to install qtopia? where can I find a .img
ubuntu file equivalent to 'rootfs_qtopia_qt4.img'
Screwface
You can have a look at the near end of this post. Reggie has translated the
readme textfile using google.
http://www.friendlyarm.net/forum/topic/4708
