Hi, I am trying to load ubuntu on the following board without success. version : 1220 CPU : S3C6410 533Mhz RAM : 256MB NAND : 256MB(SLC) ID: ECDA1095 LCD Type : H43(auto) FriendlyArm.ini settings that i used -------------------------------------------------- LCD-Mode = Yes LCD-Type = h43 CheckOneButton=No Action=install OS= Ubuntu VerifyNandWrite=No StatusType = Beeper| LED #################### Ubuntu ##################### Ubuntu-BootLoader = superboot-6410.bin Ubuntu-Kernel = Ubuntu/uzImage_n43 Ubuntu-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 Ubuntu-RootFs-InstallImage = Ubuntu/rootfs_ubuntu-slc.ubi Ubuntu-RootFs-RunImage = Ubuntu/rootfs_ubuntu.ext3 The install runs fine till 82% and then stops with an error. I even tried to install with following setting (even thought he NAND said SLC), but this stopped at 79% Ubuntu-RootFs-InstallImage = Ubuntu/rootfs_ubuntu-mlc2.ubi Please suggest a way out ?
tiny6410 - ubuntu install problems
Hi, I want to approach something like you where did you get the rootfs_ubuntu.ext3 from? Are you sure it is possible to use the uzImage_n43 for the H43 Display?
Another question, because I created now a runimage too, but mine got 800MB! And my Kernel is about 70 MB, together with the Bootloader I don't have enough space on my 1GB SD Card. If yours gets big too, perhaps thats the reason why it doesn't continue after like 80%?
>Another question, because I created now a runimage too, but mine got 800MB! >And my Kernel is about 70 MB, together with the Bootloader I don't have enough space on my 1GB SD Card. If yours gets big too, perhaps thats the reason why it doesn't continue after like 80%? I have a 4G card, so i should not be an issue. however, the NAND flash is only 256 MB, so i dont know how that factors in.
Hi, I got it running now on my SD Card. I had the wrong file which I thought would be my Kernel, so that problem was solved. At the end because of the display difference between the N43 and the H43, I took the Android Kernel for the H43 (azImage_h43) together with my 800MB runimage (xubuntu) and it went very well (you just have to connect a keyboard, because you have to "startxfce4" (atleast I had to do so)). Did you try to run it from SD Card either?
Okay when I try to install (my slc ubi is around 307MB), it starts beeping and says "failed" to on 82%. I would say you should try to start it from SD card as I think this is a problem with the space on the nand (if your ubi is 307MB to - calculate - 307 MB = ~100%, 251 MB = ~82%, NAND Flash = ~256MB, add the bootloader - and you are at the limit. So I recommend you to start from sd card just for testing purpose.
> Okay when I try to install (my slc ubi is around 307MB), it starts beeping and says "failed" to on 82%. I would say you should try to start it from SD card as I think this is a problem with the space on the nand (if your ubi is 307MB to - calculate - 307 MB = ~100%, 251 MB = ~82%, NAND Flash = ~256MB, add the bootloader - and you are at the limit. > So I recommend you to start from sd card just for testing purpose. Please say what setting did you use for the ini file and also how did you create the ext3 file cause that was not there on the DVD?
please also say where you got the xubuntu file, the disk which i have only has the ubuntu direrctory
Hi, I'm sorry but I am currently not in front of my computer from work (I had tested it there), but the important changes I did to the FriendlyARM.ini were the following: action=run OS=Ubuntu then: ################### Ubuntu ##################### # I had the superboot on the same fs depth like FriendlyARM.ini Ubuntu-BootLoader = superboot-*someNumbersIDon'tRemember*.bin # Jeah I know this is "the one" for android, but as I have watched the # config and did a diff on the n43 and h43 I have seen there was only one # line, and I was to lazy recompiling the whole thing when it should be # just the same. At least for me, it worked perfectly, so just try it, # this way you won't have this wrongColorPixels Ubuntu-Kernel = Ubuntu/azImage_h43 # no changes here Ubuntu-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 #not needed for running on sdcard (I hadn't enough space because of too big ext3 Ubuntu-RootFs-InstallImage = Ubuntu/rootfs_ubuntu.ubi # This one is needed and I will try to explain what I did Ubuntu-RootFs-RunImage = Ubuntu/rootfs_ubuntu.ext3 I had to make the .ext3 myself because I haven't found it anywhere on disk2. So: On Disk one ( ftp://ftp.friendlyarm.net/mini6410-tiny6410/Tiny6410A-20120726.iso ) I extracted the Ubuntu_rootfs_*someOtherNumbersIDontRemember*.tar.gz to a subfolder in my home dir mkdir ~/my_temp_working_dir tar -xzf /mnt/cdrom/Ubuntu/ubuntu_rootfs_*theSameNumbersBlabla*.tar.gz ~/my_temp_working_dir/ cd into your ~/my_temp_working_dir you will now need some tools which are on one of the two cds ( ftp://ftp.friendlyarm.net/mini6410-tiny6410/Tiny6410A-20120726.iso or ftp://ftp.friendlyarm.net/mini6410-tiny6410/Tiny6410B-20120726.iso ) they are packed in a tools subfolder - in there you can find an mkext3 or something like that. Put that app into the same folder (for example) and do ./mkext3 ubuntu_rootfs_*againAllThoseNumbers* ubuntu_rootfs.ext3 it will work for some time and then you get a big .ext3 file. That was the one I used and it was like 800MBs big. I guess there are a lot of programs and files in it, which aren't for any use if you use a small display like 4.3", but for testing purpose it's fine. After booting you will see that you wake up in a tty - just call startxfce4 and wait a bit, afterwards the tty will get a window and you will be happy :). P.S.: you will notice that most windows are not possible to scale down for a 4.3" 470x272 display so it isn't that fun I thought - but if you want to create your own programs and play a bit with it, I'm sure you will be happy with it :) have fun and happy hacking
long stories short: extract the ubuntu rootfs from the CD A (most actual version) and call the mkext3 tool which is also in CD A (perhaps also B) with the first parameter the extracted folder, and the second as the output filename (for example ubuntu_rootfs.ext3) Then mix everything together like this: / - sdcard /images/ -> /Ubuntu/ -> -> /azImage_h43 -> -> /ubuntu_rootfs.ext3 -> /FriendlyARM.ini -> /superboot-xxxxxxxxxxx.bin edit the FriendlyARM.ini with correct paths and change action=run OS=Ubuntu et voila
i used this ./mkext3image ubuntu_rootfs ubuntu_rootfs.ext3 it kept showing "Permission denied" any idea to solve ?
root@ubuntu:~/ubuntu# mkext3 rootfs-ubuntu-0910 rootfs-ubuntu.ext3 mkext3: command not found root@ubuntu:~/ubuntu# mkext3image rootfs-ubuntu-0910 rootfs-ubuntu.ext3 mkext3image: command not found
the topic was too old but not complete but i am writing to some one like me that have this problem for running mkext3image need libc6-i386 package for running 32 bit executable program on 64 bit system just type sudo apt-get libc6-i386
