I build a kernel version 3.4.0,when starting,got the messy message at the bottom, and nothing goes any further, so anyone can help??? Uncompressing Linux... done, booting the kernel. <6>Booting Linux on physical CPU 0 <5>Linux version 3.4.0+ (jim@jim-laptop) (gcc version 4.4.3 (ctng-1.6.1) ) #2 Tue Jul 17 20:23:00 CST 2012 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 CPU: VIVT data cache, VIVT instruction cache Machine: MINI2440 Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) <6>S3C24XX Clocks, Copyright 2004 Simtec Electronics S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on <7>On node 0 totalpages: 4096 <7>free_area_init_node: node 0, pgdat c0432dd4, node_mem_map c046b000 <7> Normal zone: 32 pages used for memmap <7> Normal zone: 0 pages reserved <7> Normal zone: 4064 pages, LIFO batch:0 <7>pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768<c> <7>pcpu-alloc: <c>[0] <c>0 <c> Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064 <5>Kernel command line: noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0 <6>PID hash table entries: 64 (order: -4, 256 bytes) <6>Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) <6>Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) <6>Memory: 16MB = 16MB total <5>Memory: 11676k/11676k available, 4708k reserved, 0K highmem <5>Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xc1800000 - 0xff000000 ( 984 MB) lowmem : 0xc0000000 - 0xc1000000 ( 16 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .text : 0xc0008000 - 0xc03e6794 (3962 kB) .init : 0xc03e7000 - 0xc0409000 ( 136 kB) .data : 0xc040a000 - 0xc0433660 ( 166 kB) .bss : 0xc0433684 - 0xc046a068 ( 219 kB) <6>SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 <6>NR_IRQS:85 irq: clearing subpending status 00000002 <7>timer tcon=00000000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57 <6>sched_clock: 32 bits at 200 Hz, resolution 5000000ns, wraps every 4294967291ms <6>Console: colour dummy device 80x30 <6>Calibrating delay loop... <c>201.52 BogoMIPS (lpj=503808) <6>pid_max: default: 32768 minimum: 301 <6>Mount-cache hash table entries: 512 <6>CPU: Testing write buffer coherency: ok <6>Setting up static identity map for 0x302faa98 - 0x302faaf0 <6>gpiochip_add: registered GPIOs 0 to 23 on device: GPIOA <6>gpiochip_add: registered GPIOs 32 to 47 on device: GPIOB <6>gpiochip_add: registered GPIOs 64 to 79 on device: GPIOC <6>gpiochip_add: registered GPIOs 96 to 111 on device: GPIOD <6>gpiochip_add: registered GPIOs 128 to 143 on device: GPIOE <6>gpiochip_add: registered GPIOs 160 to 167 on device: GPIOF <6>gpiochip_add: registered GPIOs 192 to 207 on device: GPIOG <6>gpiochip_add: registered GPIOs 224 to 234 on device: GPIOH <6>gpiochip_add: registered GPIOs 256 to 271 on device: GPIOJ <6>NET: Registered protocol family 16 <6>MINI2440: Option string mini2440=0tb <6>MINI2440: 't' ignored, touchscreen not compiled in <6>MINI2440: LCD [0:240x320] 1:800x480 2:1024x768 3:320x240 S3C2440: Initialising architecture S3C2440: IRQ Support S3C244X: Clock Support, DVS off <6>bio: create slab <bio-0> at 0 <6>usbcore: registered new interface driver usbfs <6>usbcore: registered new interface driver hub <6>usbcore: registered new device driver usb <6>s3c-i2c s3c2440-i2c: slave address 0x10 <6>s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz <6>s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter <6>Advanced Linux Sound Architecture Driver Version 1.0.25. <6>NET: Registered protocol family 2 <6>IP route cache hash table entries: 1024 (order: 0, 4096 bytes) <6>TCP established hash table entries: 512 (order: 0, 4096 bytes) <6>TCP bind hash table entries: 512 (order: -1, 2048 bytes) <6>TCP: Hash tables configured (established 512 bind 512) <6>TCP: reno registered <6>UDP hash table entries: 256 (order: 0, 4096 bytes) <6>UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) <6>NET: Registered protocol family 1 <6>jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. <6>ROMFS MTD (C) 2007 Red Hat, Inc. <7>yaffs: yaffs built Jul 17 2012 20:17:06 Installing. <6>msgmni has been set to 22 <6>io scheduler noop registered <6>io scheduler deadline registered <6>io scheduler cfq registered (default) <6>Console: switching to colour frame buffer device 60x53 <6>fb0: s3c2410fb frame buffer device <6>s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440 ��p��~��&am p;#65533;�����ᦙ 3;~������&a mp;#65533;����� 5533;~�����ʏ 33;�����~�&am p;#65533;�����&# 65533;���~��� ;~���p?8�?�ʏ 33;������ ~8 ========================================================================= HERE is my config # # Automatically generated file; DO NOT EDIT. # Linux/arm 3.4.0 Kernel Configuration # CONFIG_ARM=y CONFIG_HAVE_PWM=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_GENERIC_GPIO=y CONFIG_ARCH_USES_GETTIMEOFFSET=y CONFIG_KTIME_SCALAR=y CONFIG_HAVE_PROC_CPU=y CONFIG_NO_IOPORT=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_HAVE_LATENCYTOP_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_PROBE=y CONFIG_RWSEM_GENERIC_SPINLOCK=y CONFIG_ARCH_HAS_CPUFREQ=y CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_VECTORS_BASE=0xffff0000 CONFIG_ARM_PATCH_PHYS_VIRT=y CONFIG_NEED_MACH_IO_H=y CONFIG_GENERIC_BUG=y CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" CONFIG_HAVE_IRQ_WORK=y # # General setup # CONFIG_EXPERIMENTAL=y CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 CONFIG_CROSS_COMPILE="" CONFIG_LOCALVERSION="" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_XZ=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_KERNEL_GZIP=y # CONFIG_KERNEL_LZMA is not set # CONFIG_KERNEL_XZ is not set # CONFIG_KERNEL_LZO is not set CONFIG_DEFAULT_HOSTNAME="(none)" CONFIG_SWAP=y CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y # CONFIG_BSD_PROCESS_ACCT is not set # CONFIG_FHANDLE is not set # CONFIG_TASKSTATS is not set # CONFIG_AUDIT is not set CONFIG_HAVE_GENERIC_HARDIRQS=y # # IRQ subsystem # CONFIG_GENERIC_HARDIRQS=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_GENERIC_IRQ_CHIP=y # # RCU Subsystem # CONFIG_TINY_RCU=y # CONFIG_PREEMPT_RCU is not set # CONFIG_TREE_RCU_TRACE is not set # CONFIG_IKCONFIG is not set CONFIG_LOG_BUF_SHIFT=17 # CONFIG_CGROUPS is not set # CONFIG_CHECKPOINT_RESTORE is not set CONFIG_NAMESPACES=y CONFIG_UTS_NS=y CONFIG_IPC_NS=y CONFIG_USER_NS=y CONFIG_PID_NS=y CONFIG_NET_NS=y # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_SYSFS_DEPRECATED is not set CONFIG_RELAY=y CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_XZ=y CONFIG_RD_LZO=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_SYSCTL=y CONFIG_ANON_INODES=y CONFIG_PANIC_TIMEOUT=0 # CONFIG_EXPERT is not set CONFIG_UID16=y # CONFIG_SYSCTL_SYSCALL is not set CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_ALL is not set CONFIG_HOTPLUG=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y # CONFIG_EMBEDDED is not set CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # # Kernel Performance Events And Counters # # CONFIG_PERF_EVENTS is not set # CONFIG_PERF_COUNTERS is not set CONFIG_VM_EVENT_COUNTERS=y CONFIG_SLUB_DEBUG=y # CONFIG_COMPAT_BRK is not set # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_PROFILING is not set CONFIG_HAVE_OPROFILE=y # CONFIG_KPROBES is not set # CONFIG_JUMP_LABEL is not set CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_CLK=y CONFIG_HAVE_DMA_API_DEBUG=y CONFIG_HAVE_ARCH_JUMP_LABEL=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_HAVE_GENERIC_DMA_COHERENT=y CONFIG_SLABINFO=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y CONFIG_MODULE_FORCE_LOAD=y CONFIG_MODULE_UNLOAD=y CONFIG_MODULE_FORCE_UNLOAD=y # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set CONFIG_BLOCK=y CONFIG_LBDAF=y # CONFIG_BLK_DEV_BSG is not set # CONFIG_BLK_DEV_BSGLIB is not set CONFIG_BLK_DEV_INTEGRITY=y # # Partition Types # CONFIG_PARTITION_ADVANCED=y # CONFIG_ACORN_PARTITION is not set # CONFIG_OSF_PARTITION is not set # CONFIG...stripped-down
