tslib touch random mouse behaviour
miniarm
I have corss compiled tslib and Qt 4.5 for ARM and ported to board. I have
exported all the environment variable and try to run ts_calibrate, however
its working fine, I am able to generate pointercal file with the
calibration utility, after I run QT program, but when i touch the screen
mouse not come at the touch point, its flickr on the screen and touch
screen is not working.
I have run cat /dev/input/event0 and I am able to see random char. on the
screen, I also run evtest utility it also working.
After calibration, i run qt Application/demo and touch the screen, but
mouse flickr on th screen and its not setting at a point hence touch screen
not working. I have also added tslib cflags and ldfals while compileing QT
but still problem persist.
could you please let me know the possible solutions why this behavior is
happening?
I read the forum and tried all the possible steps listed in this forum, now
I am looking a technical response, I am not able to understand what I am
doing wrong.
Look forward to hear from you soon.
regards,
miniarm
Tell us what is in the ts.conf file.
Also, which mini2440 and more importantly which touchscreen.
miniarm
ts.conf
# Uncomment if you wish to use the linux input layer event interface
module_raw input
# Uncomment if you're using a Sharp Zaurus SL-5500/SL-5000d
# module_raw collie
# Uncomment if you're using a Sharp Zaurus SL-C700/C750/C760/C860
# module_raw corgi
# Uncomment if you're using a device with a UCB1200/1300/1400 TS interface
# module_raw ucb1x00
# Uncomment if you're using an HP iPaq h3600 or similar
# module_raw h3600
# Uncomment if you're using a Hitachi Webpad
# module_raw mk712
# Uncomment if you're using an IBM Arctic II
# module_raw arctic2
module pthres pmin=1
module variance delta=30
module dejitter delta=100
module linear
mini2440 1GB with 7inch screen. don't know why mouse flickr constantly
while ts_calibrate working fine.
My ts.conf is
module_raw input
#module variance delta=30
module linear
I am not using the 7" but I think these values from the Pengutronix BSP are
OK for the 7" screen.
If that doesn't help maybe show us all your ENVIRONMENT VARIABLES for Qt.
