Hi Everyone! I'm currently working on a Ethernet Driver(DM9000) for Application Specific (No OS) development, but i'm a bit stuck and stated to believe that my DM9000 is defective. So i'm here to ask for who have a MINI2440 board to test this small test build to confirm or dismiss this hypothesis. Please just Download And Run the attached bin with DNW and post what was the result. it should be something like this: DM9000 ChipId is 90000A46 DM9000 ID correct Thanks in advance!
MINI2440 - DM9000 No OS Driver Problem
I have a similar problem. I am trying to read out the chip ID for the DM9000. Every time I try to read it after a reset - the first address reads correctly then the next one reads the same thing. ax = dm9000_reg_read(0x0028); bx = dm9000_reg_read(0x0029); Uart_Printf("VIDL is %x\n", ax); Uart_Printf("VIDH is %x\n", bx); Both Uart outputs will read 46. If I read 29 first they both read 0a and ect. I think this is some kind of timing set up problem. Any ideas ?
