I have a FriendlyARM Mini210 SBC. I am trying to run Ubuntu from the SD card. From what I can tell, the way to do this is to partition the SD card. The first partition is FAT32 and contains the file superboot210 from the ftp site in the images rar in the ubuntu-210 directory. The second partition is ext3 and contains the images folder (FriendlyArm.ini and zImage). I have tried to do this two ways. First, I tried to use the provided tool SDFlasher. I consistently get an error saying that "The drive cannot find the sector requested" I have also tried following instructions from this website: http://unix.stackexchange.com/questions/39556/how-can-the-job-of-sdflash.... I am able to partition the card and copy superboot and the image to the card. However, when I try to boot the Mini210, I get a single beep followed by a high pitch whine with LED6 lit (not flashing). Nothing shows up on the screen. Does anyone have any instructions on getting this to work? I would really appreciate any help anyone can give. Thanks.
booting Ubuntu from SD Card on Mini210
The ext3 needs an images directory containing the .ini script, and an unbuntu directory with a copy of superboot and your zImage, unless you have changed the paths in the script. There is also usually a copy of superboot in the images directory - not sure at the moment which one gets used. I would have thought the ubuntu setup would load u-boot and have a uImage. I have not tried it on the 210. I'll check the master DVD iso in the morning.
Thank you for your help. To clarify, the file structure should be: In the FAT32 partition: Superboot210.bin In the EXT3 partition: images directory FriendlyArm.ini ubuntu directory Superboot210.bin zImage Is that correct?
This is the .ini file I am using. The only change I made was to make the Action Run instead of Install. I did what TheRegnirps suggested and followed the instructions on http://www.friendlyarm.net/forum/topic/3787 using dd with seek=1 #This line cannot be removed. by FriendlyARM(www.arm9.net) CheckOneButton=No Action = Install OS = Linux LCD-Mode = No LCD-Type = W50 LowFormat = No VerifyNandWrite = No CheckCRC32=No StatusType = Beeper | LED ################### Linux #################### Linux-BootLoader = Superboot210.bin Linux-Kernel = Linux/zImage Linux-CommandLine = root=/dev/mmcblk0p2 rootfstype=ext4 console=ttySAC0,115200 init=/sbin/init
Same problem here, it appears that the kernel trying to mount root from mmcblk0p2 before sd card are fully recognized by it. And both rootwait and rootdelay kernel options have no effects. I tried to modify the init script in the initramfs without success either. BTW, mine is a mini210s.
Looking at the code, if I got the right, it's in the sdhci-s3c.c file, it looks like there are some quirks in there that may or may not conflict, there is a timeout quirk, although that doesn't really explain why it seems to ignore it. I wonder if booting to a usb drive of some kind would allow you to see what's going on with the sd driver?
Hi: I also have a mini210 and was having the same problem, but then I realized that SD card was being recognized as mmcblk0p1, so I changed this line on the .ini file: Linux-CommandLine = root=/dev/mmcblk0p1 rootfstype=ext4 console=ttySAC0,115200 init=/sbin/init as you can see I changed mmcblk0p2 for mmcblk0p1. after this, ubuntu is booting (very slow) but sill there are some issues, I get this line: mountall: Event failed and then I get a lot of these lines: init: Failed to create pty - disabling logging for job any idea?
