SECBULK
Mike
do i have to install SECBULK.sys in my mini2440 with VGA board in order to
use USB mouse? how do i install it?
Roger
What OS are you using?
SECBULK.sys is the FriendlyARM dowload driver for the host pc.
Chris
I use Ubuntu, but by compile of secbulk module, get a failure.
With:
make -C /lib/modules/`uname -r`/build M=`pwd` modules
I want to compile and these are the failures:
make: Gehe in Verzeichnis '/usr/src/linux-headers-2.6.31-22-generic'
  CC [M]  /witech/dnw_linux/secbulk/secbulk.o
/witech/dnw_linux/secbulk/secbulk.c: In function ‘secbulk_write’:
/witech/dnw_linux/secbulk/secbulk.c:58: warning: comparison of distinct
pointer types lacks a cast
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /witech/dnw_linux/secbulk/secbulk.mod.o
  LD [M]  /witech/dnw_linux/secbulk/secbulk.ko
make: Verlasse Verzeichnis '/usr/src/linux-headers-2.6.31-22-generic'
I can load this module with "insmod ./secbulk.ko", but when I connect all I
get a failure that dnw cannot open /dev/secbulk0.
In dmesg is all loaded.
Do you have an idea how I can fix this?
cirus
HELP, URGENT.secbulk.sys
grazie cirus italia
http://www.friendlyarm.net/dl.php?file=dnw.zip
I think they are in here.
melih
if you are getting this error;
"Can not open /dev/secbulk0: No such file or directory"
First;
$ cd /dev/
$ ls
and find the "secbulkX" and note the "X" number
You can modify the sourcefile usbpush/dnw-linux/src/dnw.c
this lines will change
$nano dnw.c
const char* dev = "/dev/secbulk0";
#define BLOCK_SIZE  (1*1024*1024)
with this
const char* dev = "/dev/secbulk1";   // "1" is my X number
save and remake.
cheers.
