Mini2440 - Help with Samba Service
CRASHOVERRIDE
   Anyone installed the samba service on mini2440 with success??? Because i
try to install through buildroot2012.05, but when i boot the kernel in the
board the kernel block in the "starting smb service:". The version used in
this case is 3.5.15.
   I try to cross compile the samba 3.6.6 provided in the samba homepage
and no luck again.
   If anyone can help me with this matter i would be apreciated.
Regards,
CRASHOVERRDIE
CRASHOVERRIDE
This is my boot and my error:
U-Boot 1.3.2-mini2440 (Oct  6 2009 - 12:51:09)
I2C:   ready
DRAM:  64 MB
Flash:  2 MB
NAND:  128 MiB
USB:   S3C2410 USB Deviced
In:    serial
Out:   serial
Err:   serial
MAC: 04:25:fe:ed:00:18
Hit any key to stop autoboot:  0
trying to detect SD Card...
Manufacturer:       0x02, OEM "TM"
Product name:       "SD02G", revision 4.8
Serial number:      2882826801
Manufacturing date: 6/2009
CRC:                0x61, b0 = 1
READ_BL_LEN=15, C_SIZE_MULT=7, C_SIZE=365
size = 1642070016
2616368 bytes read
## Booting kernel from Legacy Image at 31000000 ...
   Image Name:   Linux-3.4.4
   Created:      2012-07-03   0:28:03 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2616304 Bytes =  2.5 MB
   Load Address: 30008000
   Entry Point:  30008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.4.4 (crashoverride@VPCF1) (gcc version 4.6.1 (Sourcery
CodeBench Lite 2011.09-70) ) #1 Tue Jul 3 01:27:50 WEST 2012
CPU: VIVT data cache, VIVT instruction cache
Machine: MINI2440
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: root=/dev/mmcblk0p3 rw rootwait rootfstype=ext3
console=ttySAC0,115200
PID hash table entries: 256 (order: -2, 1024 bytes)
Memory: 64MB = 64MB total
Memory: 59892k/59892k available, 5644k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xc4800000 - 0xff000000   ( 936 MB)
    lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc04626e8   (4458 kB)
      .init : 0xc0463000 - 0xc0486000   ( 140 kB)
      .data : 0xc0486000 - 0xc04b1f80   ( 176 kB)
       .bss : 0xc04b1fa4 - 0xc04eb770   ( 230 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:85
irq: clearing pending status 02000000
sched_clock: 32 bits at 200 Hz, resolution 5000000ns, wraps every
4294967291ms
Calibrating delay loop... 201.52 BogoMIPS (lpj=503808)
pid_max: default: 32768 minimum: 301
Setting up static identity map for 0x30366848 - 0x303668a0
gpiochip_add: registered GPIOs 0 to 23 on device: GPIOA
gpiochip_add: registered GPIOs 32 to 47 on device: GPIOB
gpiochip_add: registered GPIOs 64 to 79 on device: GPIOC
gpiochip_add: registered GPIOs 96 to 111 on device: GPIOD
gpiochip_add: registered GPIOs 128 to 143 on device: GPIOE
gpiochip_add: registered GPIOs 160 to 167 on device: GPIOF
gpiochip_add: registered GPIOs 192 to 207 on device: GPIOG
gpiochip_add: registered GPIOs 224 to 234 on device: GPIOH
gpiochip_add: registered GPIOs 256 to 271 on device: GPIOJ
MINI2440: Option string mini2440=0tb
MINI2440: 't' ignored, touchscreen not compiled in
MINI2440: LCD [0:240x320] 1:800x480 2:1024x768 3:320x240
S3C2440: IRQ Support
bio: create slab <bio-0> at 0
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
Advanced Linux Sound Architecture Driver Version 1.0.25.
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NFS: Registering the id_resolver key type
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
ROMFS MTD (C) 2007 Red Hat, Inc.
msgmni has been set to 116
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Console: switching to colour frame buffer device 60x53
s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440
console [ttySAC0] enabled
s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440
brd: module loaded
at24 0-0050: 1024 byte 24c08 EEPROM, writable, 16 bytes/write
s3c24xx-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns
s3c24xx-nand s3c2440-nand: NAND soft ECC
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V
8-bit)
Creating 4 MTD partitions on "nand":
0x000000000000-0x000000040000 : "u-boot"
ftl_cs: FTL header not found.
0x000000040000-0x000000060000 : "u-boot-env"
0x000000060000-0x000000560000 : "kernel"
0x000000560000-0x000008000000 : "root"
dm9000 Ethernet Driver, V1.31
eth0: dm9000e at c4862300,c4864304 IRQ 51 MAC: 04:25:fe:ed:00:18 (chip)
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver libusual
mousedev: PS/2 mouse device common for all mice
s3c-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2410_wdt: S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq disabled
cpuidle: using governor ladder
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
s3c-sdi s3c2440-sdi: powered down.
s3c-sdi s3c2440-sdi: mmc0 - using pio, sw SDIO IRQ
s3c-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz).
s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz).
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHkjournald starting.
 Commit interval 5 seconds
EXT3-fs (mmcblk0p3): using internal journal
EXT3-fs (mmcblk0p3): recovery complete
EXT3-fs (mmcblk0p3): mounted filesystem with ordered data mode
VFS: Mounted root (ext3 filesystem) on device 179:3.
Freeing init memory: 140K
Starting logging: OK
Initializing random number generator... done.
Starting network...
Starting SMB services: BUG: scheduling while atomic: mmcqd/0/763/0x00000100
Modules linked in:
[<c000dc44>] (unwind_backtrace+0x0/0xf0) from [<c0365f94>]
(__schedule+0x30c/0x35c)
[<c0365f94>] (__schedule+0x30c/0x35c) from [<c036537c>]
(__mutex_lock_slowpath+0x64/0x94)
[<c036537c>] (__mutex_lock_slowpath+0x64/0x94) from [<c01a97ec>]
(gpio_unexport+0x18/0xb0)
[<c01a97ec>] (gpio_unexport+0x18/0xb0) from [<c01a9898>]
(gpio_free+0x14/0x10c)
[<c01a9898>] (gpio_free+0x14/0x10c) from [<c02771d4>]
(s3c24xx_led_set+0x20/0x44)
[<c02771d4>] (s3c24xx_led_set+0x20/0x44) from [<c027767c>]
(led_heartbeat_function+0x60/0xf0)
[<c027767c>] (led_heartbeat_function+0x60/0xf0) from [<c0022d3c>]
(run_timer_softirq+0xe0/0x21c)
[<c0022d3c>] (run_timer_softirq+0xe0/0x21c) from [<c001d904>]
(__do_softirq+0x98/0x130)
[<c001d904>] (__do_softirq+0x98/0x130) from [<c001dd14>]
(irq_exit+0x48/0x50)
[<c001dd14>] (irq_exit+0x48/0x50) from [<c0009b10>] (handle_IRQ+0x34/0x84)
[<c0009b10>] (handle_IRQ+0x34/0x84) from [<c0008ea4>] (__irq_svc+0x24/0xa0)
[<c0008ea4>] (__irq_svc+0x24/0xa0) from [<c01a97ec>]
[<c02771d4>] (s3c24xx_led_set+0x20/0x44) from [<c0276b00>]
(led_trigger_event+0x54/0x64)
[<c0276b00>] (led_trigger_event+0x54/0x64) from [<c025f77c>]
(__mmc_start_req+0xec/0x150)
[<c025f77c>] (__mmc_start_req+0xec/0x150) from [<c025fdc4>]
(mmc_start_req+0x118/0x120)
[<c025fdc4>] (mmc_start_req+0x118/0x120) from [<c026c148>]
(mmc_blk_issue_rw_rq+0x64/0x3a8)
[<c026c148>] (mmc_blk_issue_rw_rq+0x64/0x3a8) from [<c026d440>]
(mmc_blk_issue_rq+0x2b4/0x49c)
[<c026d440>] (mmc_blk_issue_rq+0x2b4/0x49c...stripped-down
Juergen Beisert
You hit a kernel bug, not a samba bug.
CRASHOVERRIDE
Hi Juergen Beisert,
   The kernel without a samba package works fine, you have a kernel with a
samba package on board running? I really need help with this problem or
another way to share files from the board with windows.
Regards,
CRASHOVERRIDE
Juergen Beisert
You can try my BSP (refer http://www.friendlyarm.net/forum/topic/2737) and
enable the 'samba' server in the menu.
I tried it here:
Linux version 3.4.4-ptx-2012.06.0 (jb@isonoe) (gcc version 4.6.2
(OSELAS.Toolchain-2011.11.git) ) #2 PREEMPT Thu Jun 28 22:24:42 CEST 2012
Starting Samba server: /usr/sbin/smbd. /usr/sbin/nmbd. done
root@mini2440:~ ps ax
  391 ?        Ss     0:00 /usr/sbin/smbd -D
  393 ?        S      0:00 /usr/sbin/smbd -D
  394 ?        Ss     0:00 /usr/sbin/nmbd -D
