GLIBC issues
Yohan Fernando
I have successfully compiled the target build for my mini6410.
I used Qt4.7.4 and the 4.5.1 toolchain.
I copied the libraries, and set the parameters in cd /etc/init.d/rcS and cd
/etc/profile
I tried running the examples and demos which were built as part of the
target build but they did not execute. They came up with some GLIBC error.
Thereafter, I installed the SDK, and then used one of the given examples
(analogclock) and then re-built it, and compiled it for the target board. I
used the "file" command for the executable and it came up with this,
analogclock: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically
linked (uses shared libs), for GNU/Linux 2.6.27, not stripped
I copied the executable, changed permissions, and when I executed it(via
telnet) I got this error,
./analogclock: /lib/libc.so.6: version `GLIBC_2.9' not found (required by
/usr/local/qt/lib/libQtGui.so.4)
./analogclock: /lib/libc.so.6: version `GLIBC_2.10' not found (required by
/usr/local/qt/lib/libQtNetwork.so.4)
/usr/local/qt/lib/libQtCore.so.4)
This was for both the execution commands "./analogclock -qws" and
"./analogclock"
One thing I must say is that my board is very similar to the mini6410. It
is the idea 6410 and has the exact specs and processor. I was given a
toolchain with the board (4.2.2) and it comes up as
"arm-unknown-linux-gnueabi" so should I use that toolchain? Or will the
toolchain not affect this GLIBC error?
How do I fix this?
Dhruv Vyas
Hello...
try this thread...
http://www.friendlyarm.net/forum/topic/2097
put on board latest zImage and latest qtopia image and follow the
instruction from the thread...
I successfully tested fluidlauncher demo with it...
