hi.. all . . While building the native compiler for ARM, Facing the following error. . . checking for /opt/arm/bin/arm-none-linux-gnueabi-gcc option to accept ISO C89... none needed checking for /opt/arm/bin/arm-none-linux-gnueabi-gcc option to accept ISO C99... -std=gnu99 checking for /opt/arm/bin/arm-none-linux-gnueabi-gcc -std=gnu99 option to accept ISO Standard C... (cached) -std=gnu99 checking how to run the C preprocessor... /opt/arm/bin/arm-none-linux-gnueabi-gcc -std=gnu99 -E checking build system compiler /opt/arm/bin/arm-none-linux-gnueabi-gcc... yes checking for build system preprocessor... /opt/arm/bin/arm-none-linux-gnueabi-gcc -E checking for build system executable suffix... configure: error: Cannot determine executable suffix make[1]: *** [configure-gmp] Error 1 make[1]: Leaving directory `/root/native_arm/build/native-gcc' . . . I used following command to configure. . . ../../sources/gcc-4.4.4/configure --build=$BUILDMACH --host=$TARGETMACH --target=$TARGETMACH --prefix=$INSTALLDIR --with-gmp-include=$(pwd)/gmp --with-gmp-lib=$(pwd)/gmp/.libs --enable-language=c --with-gnueabi-ld --with-gnueabi-as --enable-threads=posix --disable-multilib --disable-werror . .
